Routes
Started by dumpty, August 20, 2008, 07:37:27 AM
Just to show the pudding again :)
Glyns setup is showing most Central and South UK.
http://www.glyn.tzo.net/
Akbars is more zoomed in on the London region
http://www.akzah.com/blog/static.php?page=radarboxLondon
Both are showing without the network at the moment and using the online routes (Glyn may have added extra routes) but the routes are showing for 90%+
#76
Quote from: AirNav Support on September 23, 2008, 08:58:39 PMOverall you must understand that if you want 100% routes across the world then the system at the moment does not exist even for a Professional.
My advise to anyone that wants near 100% routes is to use Planeplotter and FD6.  I run this setup 24x7, and get 100% route lookup.  FD6 uses three sources for it's routes - Flytcom, Flightstats, and FlightAware.
Sure, once a day you have to import the new/changed routes in ANRB, so any route changes are always a day late.  But having run this setup for months now, I only get around 10-20 new/changed routes each day anyway.  In my routes database, I now have over 2,700 routes that have been added or changed using this process.
See http://www.airnavsystems.com/forum/index.php?topic=551.msg4199#msg4199 for details on how to do this.
GlynH
Quote from: AirNav Support on September 26, 2008, 07:38:37 AM
Just to clarify I never have Network flights showing as I am only interested in aircraft that I can 'see'.
I have not added any extra routes nor modified my databse in any way, shape or form.
I still have the joys of that all to come! :-)
-=Glyn=-
