Ten days later
Started by paagats, July 20, 2007, 11:23:21 AM
paagats
I'm in Sydney (AU) about 40km from Syd Airport (as the crow flies) 58km by road!.
I checked power settings and from memory I selected 'never' (switch off).
This morning I was trying to recover a log and for some reason it kept wanting to open Internet Explorer? I must have closed RadarBox by mistake and when I went to restart it asks for my logon details (which I remember saving) and even after entering the details thrre was no response so I had to re-install which meant I lost all this mornings log and a/c updates to Database Explorer.
This happened the other day so was wondering why the laptop is not rembering my logon (registration) details.
Left it running last night and seemed okay this morning.
Will check settings again tonight and see what happens in the morning.
If you are using Vista paagats, make sure you right click on the RadarBox icon and select run with admin rights. That should fix your registration issue.
paagats
thank you, will try that.
paagats
Thanks that worked fine. Still getting used to Vista as you have to continually okay anything you want to do.
