Trouble starting application
Started by kazandlee, September 24, 2008, 10:25:06 PM
kazandlee
It says hardware not connected, and the small box is higlighted red.
When you start RadarBox 2009, look at the RadarBox device and tell us what lights are flashing.
kazandlee
The Blue USB light is flashing, and of course the power light is permanent green.
If you close RadarBox 2009 and it still flashes blue that means you have not installed the drivers.
kazandlee
Ok will install the main disc that came with the box. brb
Check in Windows Device Manager.  You should see Airnav Radarbox listed udner USB devices - as in this picture - http://www.airnavsystems.com/forum/index.php?topic=1396.msg10599#msg10599
You don't need the drivers from the CD, the drivers are already on your PC in folder C:\Program FIles\AirNav Systems\AirNav RadarBox 2009\Drivers
kazandlee
Have just reistalled the disc, still exactly the same, when i o into device manager it says no device found????
Connect RadarBox, open up Windows Device Manager and find the RadarBox device it will have an exlamation mark next to it. Right click on it and update driver to  C:\Program FIles\AirNav Systems\AirNav RadarBox 2009\Drivers
kazandlee
Yipeee,
Thats done the trick, thanks for all your paitence,
Caroline.
