Author Topic: MyLog  (Read 15686 times)
viking9
    • Aircraft Photography
Re: MyLog
« Reply #15 on: October 23, 2008, 09:57:41 PM »
I knew it was too good to be true. The output I'm getting is:
Last Date/time, First Date/Time, Ac Type long, Ac Type short, Airline, Mode-S, Country, Registration, ADS-B. This is the same info as MyLog.
However, if I play the file back in RB then all the info, including squawk is here.
Am I doing something wrong?
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
Re: MyLog
« Reply #16 on: October 24, 2008, 08:01:39 AM »
viking9, if the squawk appears on replay, then it must be saved in the recording file!!  Each line in the recording file should look like this:
$PTA,20081023092335699,400940,,33800,420.0,341.0,-2176,,55.7847,-3.1775,5072,
1. Are you running latest version of ANRB 2009?
2. Which folder did you save the recording file in?  The default location is \AirNav Systems\AirNav RadarBox 2009\Recorder.
3. If you're running Vista, the recording file will be in the Virtual Store.
viking9
Re: MyLog
« Reply #17 on: October 24, 2008, 12:04:09 PM »
Tarbat,
I'm running Vista Home Premium SP1. I don't have a folder C:\Users\xxxxxxxx\AppData\Local\VirtualStore\Program Files\AirNav Systems\AirNav RadarBox 2009\Data. In fact I don't have any Appdata folder. That's possibly due to doing an upgrade from XP to Vista.
Anyway I just decided to reinstall ANRB 2009 on another drive and the everything is working fine with the .rbl files now being stored in the Recorder folder. They now contain the squawk codes which makes me a much happier man.
Many thanks your help.
Tom
Tom
15 miles SE of EGUN
