Track or Heading?
Started by DaveReid, November 24, 2008, 03:19:42 PM
Quote from: AirNav Support on November 25, 2008, 02:44:18 PM
Someone in the US should get plenty of them
Or indeed any RB user in the southern UK - I've had 17 different UAL B772 flights so far today on SBS.
I take your point that it needs to be a user who gets them locally and not via the network - anyone using RB near Heathrow ?
Cumulus
Approx 1614z two aircraft LX-N90443 and S2-ADK showing IAS
Cheers,
Peter
Thanks Peter, What have you picked up which is at 84,600ft?
Cumulus
Must be that guy with the white beard and red coat, they were building his grotto in the shopping centre today.
Thanks, guys - that's impressive, and also something that the SBS can't do.
I'm worried about that Bangladeshi, though - the A310's Vmo is 360kt, so the wings must have been in danger of falling off at 456kt IAS !!
Dave
viking9
Quote from: DaveReid on November 25, 2008, 04:57:42 PM
Dave
I thought that the A310 series had a max cruise speed of around 0.85 mach, 485 kt at 35,000 ft!
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
Quote from: viking9 on November 25, 2008, 06:25:37 PMI thought that the A310 series had a max cruise speed of around 0.85 mach, 485 kt at 35,000 ft!
At 35,000ft 485kt TAS equates to approximately 285kt IAS.
viking9
Quote from: DaveReid on November 25, 2008, 06:33:44 PM
You are of course correct. Senior moment on my part. :(
Tom
Tom
15 miles SE of EGUN
Quote from: viking9 on November 25, 2008, 06:45:26 PM
I know the feeling  :-)
My original comment about the wings falling off was simply meant to illustrate that the column in the display labelled "IAS" isn't IAS at all, it's TAS which, as we know, is something completely different.
AirNav ?
The Enhanced Mode S IAS is where we are getting the data from for that column but as the 86,000ft and various other anomalies we see in some of the Mode-S Enhanced or ADS-B data it all depends on the actual aircraft and whether its correctly setup.
However we have seen some American aircraft display values in the 250-280 but can't remember whether these were descending rather than at cruise level.
Unfortunately the aircraft giving this extra information are rare at the moment.
Quote from: AirNav Support on November 25, 2008, 08:16:03 PM
Are you correctly decoding Bit 25 in the Airspeed/Heading Squitter ?
As far as I am as aware yes :)
I will pass on the query to the Development and Hardware just in case though.
Quote from: AirNav Support on November 25, 2008, 08:39:36 PM
Any resolution on this ?
Over the past few days I've captured nearly 140,000 Airspeed/Heading Squitters from 97 different aircraft and not one contained IAS, all were TAS, which begs the question of where you are finding aircraft that transmit IAS in the squitter?
Hello Dave: can you tell us which Mode-s/ADS-B frame number contains that information?
Quote from: AirNav Development on November 28, 2008, 08:16:47 PM
DF17 (Extended Squitter) Format Type Code 19 (Airspeed and Heading) Subtype 3 (airspeed/subsonic aircraft).  Bit 25 has values 0 (IAS) or 1 (TAS).
But surely you must know that already if you are currently displaying airspeed in RadarBox ?
