Author Topic: WHY i dont get route information from any aircraft ? + time issues  (Read 10821 times)
Re: WHY i dont get route information from any aircraft ? + time issues
« Reply #15 on: December 07, 2008, 03:56:04 PM »
asiawatcher, you should see the route displayed using ICAO codes in the MyFlights list, and as airport names in the aircraft details box - example attached.
« Last Edit: December 07, 2008, 04:16:44 PM by tarbat »
asiawatcher
« Reply #16 on: December 07, 2008, 04:51:58 PM »
right i dont get route only registration, then how do i look up the actual route from registration ? like its going to paris or london for example ?
cheers
HMN851X
« Reply #17 on: December 07, 2008, 05:21:03 PM »
yes tarbat it is ticked
« Reply #18 on: December 07, 2008, 05:55:53 PM »
Okay, then this is the known issue where the route is not checked locally if flight transitions from network to local.  Will hopefully be fixed in v2.1.
You'll only get a route if the aircraft has a Flight ID.
« Last Edit: December 07, 2008, 06:09:03 PM by tarbat »
asiawatcher
« Reply #19 on: December 07, 2008, 08:45:10 PM »
yes tarbat i got all the flight id's but unfortunately NO ROUTE
see here --> http://asiawatcher.net/help/
« Last Edit: December 07, 2008, 08:50:00 PM by asiawatcher »
« Reply #20 on: December 07, 2008, 10:04:10 PM »
Okay, I'm out of ideas, sorry.  At least 2 of those Flight IDs are in my routes table.  Are the Flight IDs in your routes table?  Maybe contact Airnav support for help.
« Last Edit: December 07, 2008, 10:08:59 PM by tarbat »
« Reply #21 on: December 07, 2008, 10:30:52 PM »
Asiawatcher,
Open your Routes Database in RadarBox. File -> Database Explorer - Choose Routes for the table. Scroll down to the bottom, do you see values in the the CH column?
Also did you use upgrade to RadarbOX 2009 or have you always been using RadarBox 2009?
asiawatcher
« Reply #22 on: December 07, 2008, 10:39:50 PM »
Hi CH column is empty all along, no values
I have always been using radarbox 2009 as i bought the hardware 2 days ago
i downloaded the version you got on website first
http://www.airnavsystems.com/download/anrb/anrb20setup.exe
to check out the demo 1 day before i buy radarbox then i seen that on the cd provided it has a slightly newer version called ANRB201Setup.exe
so then i installed that version over the 20 one i think without uninstall
do i need to uninstall and reinstall ?
cheers
