USB Extenders
Started by Jetcos, August 18, 2007, 03:07:48 PM
Dub33
Cheers Pallmall68
Dub33
Jetcos
Had it running today from 07:15 am till it stopped at 13:20pm.  Not very long, will wait for V1.4 and see if it helps.
Steve
Steve Cos
CYYZ Toronto,Canada
Jetcos,
Confirm you have 1.3 running? as 1.4 won't affect stability of USB connections as that should be fine under 1.3 (it should reconnect if the USB drops)
If you are using 1.3 then its simply the length of the USB cable which is causing the drop out.
Deadcalm
Juan, where did you get your Lantronix unit from?  There doesn't seem to be the facility to order it directly from them on line, and I can't find a French reseller.  I'd like to get hold of one of these units fairly quickly.
DC
