Author Topic: Map not displaying  (Read 16710 times)
Re: Map not displaying
« Reply #15 on: August 18, 2018, 12:50:59 PM »
I would suggest that you do it the other way Graham copy across the working files to the non working
GreekSpy2001
    • Graham's Aircraft Photos
« Reply #16 on: August 20, 2018, 01:00:46 PM »
yes did with the navdata but no change.  The map is displayed minimised and the system goes into the hour glass when I try and maximise the map.
As both copies have bugs albeit different ones will attempt to install a new fresh copy.
Can anyone advise correct procedure for installing the ve 6 SW with the win10 64bit drivers and the Airnav Micro Radarbox driver
ta
« Reply #17 on: August 20, 2018, 01:35:23 PM »
If you have a previous copy uninstall then do a manual uninstall for any orphan files left behind
Nothing special for installation Graham, just install V6 to c:\Airnav then install the drivers.  http://www.airnavsystems.com/download/ANRB/ANRB60002Setup.exe
http://www.airnavsystems.com/Download/ANRB/Drivers/microRadarbox-Drivers-20150411.exe and it should then start up as before
GreekSpy2001
« Reply #18 on: August 20, 2018, 02:47:43 PM »
installed and working better this time.  Thanks
