Excellent new antenna in the U.S.
Started by oceans777, January 23, 2009, 02:27:14 AM
Falcon
Quote from: Canonjohns40D on April 01, 2009, 11:13:34 PM
It's up it's up. Finally the aerial was mounted on the roof this evening. Initial thoughts?
WOW WOW WOW!!!!!!!
I have attached a screen shot of the polar diagram running for approx 2 hourss. I have had Tornados a first for me and well the polar diagram says it all. The aerial is on a 6ft pole on the chimney stack.
I can't wait for a full day of traffic. My flights would normally be showing around 10 maybe 14 aircraft on a good night late evening .This evening after it was erected I was in the 50+ mark.
John
Hi John,
Do you need any help in keeping yourself on the ground? A 400 - 500 percent improvement would get me jumping. Look forward to seeing the full day polar.
Darryl
Canonjohns40D
Hi Darrl boy has this hobby really taken off now (no pun intended). I run the RB overnight almost every night. With the supplied antenna mounted indoors at 8am I would normally have about 140 aircraft recorded. This morning the first for the DPD outside, I had 320 at 8am. Happy? No euphoric!!!!!!!!!!!!!!!!!
John
spikem
Hi John
Congrats mate on getting it up and running. I had an idea you wouldn't be dissapointed. Give us a look at your polar plot to see the improvement.
Martin
Canonjohns40D
HI Martin thrilled with it, what a change. I missed attaching the polar diagram last night dohh!!! In work now but I'll post it later this evening.
John
Canonjohns40D
#79
Hi all as discussed here is the polar diagram for the DPD aerial mounted externally. This is it after its first 24 hours.
I'm thrilled with the increase in contacts. it has already got me a range of aircraft types and Airlines which I had not logged before.
Maybe it's just me but does the polar diagram not look a bit like a map of Northern Ireland?
John
Ralph
Hi All
Here is another happy customer of DPD antennas.
Attached is my polar diagram centered at Wakefield West Yorkshire.
The antenna is mounted on a pole one meter above my roof ridge line.
The antenna has given me an overall improvement of about 45%.
The polar diagram was taken after 24Hrs of the antenna being installed and running.
Cheers for now.....Ralph
hamerhead
hi.
can you please tell me de name of the antena, i just got my airnav 2009 box and will be sending data from jfk, la guardia and erw 3 big airports in my area.
hava a good day.
hamerhead
Falcon
#82
Quote from: Canonjohns40D on April 02, 2009, 12:07:32 PM
Hi John,
I purchased the DPD and have had it running on the roof for a couple of months with a 100' of LMR400 with no amp and am seeing excellent results for my area. The areas that aren't blocked by hills I am getting 200+ nm with aircraft at cruising altitude and all the way down to 200-300' at an airport 20nm away and about 2000-3000' at 34nm away and that's with the signal going between the gaps in the hills in my area.
It's good to hear you are also happy with your antenna. I didn't see your reply until today.
Darryl
shadowman
hamerhead,
Here is the link to the antenna.
ADS-B Vertical Outdoor Model Antenna
http://www.dpdproductions.com/page_vhf_air.html
Hi Darryl, are you in the UK, if so who supplied the LMR400, and how much does it cost please?
Falcon
#85
Quote from: CoastGuardJon on June 29, 2009, 08:40:59 PM
I purchased it from these guy here http://www.infinitecables.com/antenna_cable-nm-nf.html I purchased 100' of LMR400, and a 3' pigtail of LMR195 to go from the LMR400 to the RB with the connectors on them. I'm not in the UK. I was concerned about the total length and signal loss but from what I had read about the DPD antenna and the LMR400, I thought I may have a chance of making it work without an amp, and it turns out I was right, at least for my installation. I may pickup more aircraft or hold onto aircraft for a longer period of time with a mast head pre-amp, but at this point with the results I am getting I don't feel compelled to fork out the extra cash.
Darryl
Hi Darryl, many thanks for the link, I was hoping for a UK source, but c'est la vie!
nortonbeak
Quote from: CoastGuardJon on July 02, 2009, 07:48:00 PM
If you are merely trying to find a UK source of LM 400, this company came up on an internet search.
http://www.wirelesspro.co.uk/department/bulk_cable/
I have no idea whether they are good, bad or indifferent, or indeed their price is good or bad.
