Author Topic: AirNav RadarBox 2007 - Version 1.2 (Patch Beta 2) Available for Download  (Read 170420 times)
Re: AirNav RadarBox 2007 - Version 1.2 (Patch Beta 2) Available for Download
« Reply #195 on: September 11, 2007, 10:27:07 PM »
Brisbane,
Have you copied the new exe and two dlls files to your RadarBox fodler as well the firmware update?
What is your driver version?
Brisbane
« Reply #196 on: September 11, 2007, 10:46:43 PM »
The 3 files are ANRB.exe 7/8/2007 02.34 1.65MB, FTDXX library 3.1.12.1 27/6/2007 14.10 197KB, crc.dll 2/8/2007 01.42 208KB. Drivers dated 14/8/2007 23.14 1.02MB.
« Reply #197 on: September 11, 2007, 10:59:46 PM »
Brisbane:
Without sounding rude, have you followed the patch instructions at the start of this post?
The reason why is that you have Version 1.1 beta files not Beta 2.
Again I repeat please users with knowledge of computers to only attempt the update. We don't have the man power to walk everybody through a beta version. For those customers you will need a wait a bit for the final release.
Sorry to sound grumpy :)
doro
« Reply #198 on: September 12, 2007, 05:51:22 AM »
Airnav, you do sound grumpy ;) Your support is excellent, so hang in there. Perhaps it is an idea to make a locked 'how to' discussion topic with a summary of the known problems and additional instructions for people that do not readback on the forum. Ronald
« Reply #199 on: September 12, 2007, 07:57:31 AM »
Brisbane, these are the Beta12 files you should have in your /AirNav RadarBox 2007/ directory:
ANRB.exe                  08/09/2007
FirmWareUpdater.exe 08/09/2007
ftd2xx.dll                   01/08/2007
rb.dll                         28/08/2007
Note the the dates.
Also, if you read back through the forum, you will see this explanation that I posted about where the patch files end up:
- When the Beta12 patch is downloaded, it is a zip file.
 - If files are unzipped using the directory parths that come with the zip, they are put in a /ARNBPatch12 and /ARNBPatch12/Drivers directory
- You then need to copy the flies manually to the appropriate locations in the AirNav RadarBox 2007 directory structure
- The 4 files in the /ANRB/ directory need copying to the /AirNav RadarBox 2007 directory
ANRB.exe
FirmwareUpdater.exe
ftd2xx.dll
rb.dll
- The 7 files in the /ARNBPatch12/Drivers directory need copying to the /AirNav RadarBox 2007/Drivers directory
ftbusui.dll
ftd2xx.dll
ftd2.h
ftd2xx.lib
ftdibus.inf
ftdibus.sys
ftlang.dll
- Once you've done this, it's the new inf file in the /AirNav RadarBox 2007/Drivers directory that you browse to when installing the new RB drivers.
« Last Edit: September 12, 2007, 09:03:15 AM by Allocator »
Brisbane
« Reply #200 on: September 12, 2007, 09:37:38 AM »
Hi allocator, it would seem that my files are a mix of new and old for some reason. ANRB dated 7/8/2007 02.34 Version0.0.0.0 1.73MB, Firmware update 8/9/2007 01.29 955KB, FTD2XX 27/6/2007 14.10 197KB, rb.dll 28/8/2007 19.38 208KB. Don't know why some files updated and not others.
Roadrunner
« Reply #201 on: September 12, 2007, 09:42:10 AM »
AirNav,
Think I have found a little bug!  I had map set at my location and pressed Esc. to fill all of screen. The map had been set not to show Vertical tracking view. When I return to the normal screen by pressing Esc. again the Vertical view returns but when I look in the drop down list it is not shown "tagged" as in use. If I click on it it "tags" and then I can turn it off.  This only occurs after using the "full screen " option.
Mike
« Reply #202 on: September 12, 2007, 09:51:34 AM »
Brisbane,
I suggest that you download the Beta12 patch again, unzip it and then copy the files manually to the correct AirNav directories so at least you have the correct files.
I don't know where you are regarding the driver update and Firmware update, but you need to EXACTLY follow the AirNav instructions at the very beginning of this thread to make sure the update works.  Also, do heed the AirNav advice below:
N.B As a cautionary measure untill more is known, do NOT attempt to update the RadarBox firmware if you have not installed the latest driver.
« Last Edit: September 12, 2007, 09:56:35 AM by Allocator »
bee46
    • leerdam radar
« Reply #203 on: September 12, 2007, 10:30:45 AM »
I installed the new drivers (beta2), and the new beta2 firmware patch, then I use the beta 1 software with the possibility to download the pictures and it seems there are no problems anymore
« Reply #204 on: September 12, 2007, 03:52:21 PM »
Locking post as post has now become too long and starting a new post with the relevant information.
