AirNav Reports vs Live Radar screen
Started by AK01, February 16, 2009, 09:24:20 PM
hfradiopro
Tarbat,
I'd be interested in how you could tweak the SQL to reflect all flights of an aircraft on a particular day, even if that flight is still in progress.  As far as I can figure out, if a flight carries over to the new day, then it does not show in this report.
I've tried to tweak the SQL code, but I am not familiar enough with it to make it work the way I'd like to.
Thanks in advance,
Dave
jgrloit
Do I understand you to mean  started or ended on a particular day?
And ALL aircraft?
Based in Hexham - Tyne Valley
hfradiopro
Exactly...something that would pull all aircraft active that day, regardless if the flight is still continuing.  The SQL above will pull all flights that have ended on a particular day, but if a flight starts at 2345 and continues past new day, then it isn't counted until the next day.
I would love to be able to pull all aircraft active at my location for the day, regardless of when they took off or landed.
#18
Quote from: hfradiopro on April 08, 2009, 01:19:29 PMThe SQL above will pull all flights that have ended on a particular day, but if a flight starts at 2345 and continues past new day, then it isn't counted until the next day.
The Flight Start Time can be unreliable if a flight gets interupted.  But this will do what you want:
SELECT DISTINCT
  Aircraft.Registration AS "Reg",
  Flights.Callsign AS "Flight ID",
  Flights.Route AS "Route",
  Aircraft.AircraftTypeSmall AS "ICAO Type",
  Aircraft.Airline AS "Airline",
  Aircraft.AircraftTypeLong AS "Aircraft",
  substr(Flights.EndTime,1,16) AS "Flight Ended",
  Aircraft.ModeS AS "Mode S"
FROM
Aircraft
LEFT OUTER JOIN Flights ON (Aircraft.ModeS=Flights.ModeS)
WHERE
  ((substr(Aircraft.LastTime,1,4)||"-"||substr(Aircraft.LastTime,6,2)||"-"||substr(Aircraft.LastTime,9,2) = date('now','-1 day')) AND
  (Flights.EndTime IS NULL)) OR
  (substr(Flights.EndTime,1,4)||"-"||substr(Flights.EndTime,6,2)||"-"||substr(Flights.EndTime,9,2) = date('now','-1 day')) OR
  (substr(Flights.StartTime,1,4)||"-"||substr(Flights.StartTime,6,2)||"-"||substr(Flights.StartTime,9,2) = date('now','-1 day'))
ORDER BY
  "Reg",
  "Mode S"
Or, if you're using my SQL bat file method:
.output data.html
.mode list
.header OFF
SELECT DISTINCT "<HTML><HEAD><Title>Radarbox Log - Yesterday</Title>" AS FIELD_1 FROM Aircraft;
SELECT DISTINCT "<STYLE type='text/css'> BODY { background: #000000; color: #FFFFFF; font-family: Arial; }</STYLE>" AS FIELD_1 FROM Aircraft;
SELECT DISTINCT "</HEAD><BODY>" AS FIELD_1 FROM Aircraft;
SELECT DISTINCT "<Table Border='1' Cellpadding='4' Cellspacing='1'>" AS FIELD_1 FROM Aircraft;
.mode html
.header ON
SELECT DISTINCT Aircraft.Registration AS "Reg",Flights.Callsign AS "Flight ID",Flights.Route AS "Route",Aircraft.AircraftTypeSmall AS "ICAO Type",Aircraft.Airline AS "Airline",Aircraft.AircraftTypeLong AS "Aircraft",substr(Flights.EndTime,1,16) AS "Flight Ended",Aircraft.ModeS AS "Mode S" FROM Aircraft LEFT OUTER JOIN Flights ON (Aircraft.ModeS=Flights.ModeS) WHERE ((date('now','-1 day') = substr(Aircraft.LastTime,1,4)||"-"||substr(Aircraft.LastTime,6,2)||"-"||substr(Aircraft.LastTime,9,2)) AND (Flights.StartTime IS NULL)) OR ((date('now','-1 day') = substr(Flights.EndTime,1,4)||"-"||substr(Flights.EndTime,6,2)||"-"||substr(Flights.EndTime,9,2))) OR ((date('now','-1 day') = substr(Flights.StartTime,1,4)||"-"||substr(Flights.StartTime,6,2)||"-"||substr(Flights.StartTime,9,2))) ORDER BY Aircraft.Registration,Flights.EndTime,Aircraft.ModeS;
.mode list
.header OFF
SELECT DISTINCT "</Table></BODY></HTML>" AS FIELD_1 FROM Aircraft;
.exit
Example report for YESTERDAY at http://www.tarbat.gofreeserve.com/data.html - you'll see 3 extra entries for flights started yesterday but ended today (8th April).
hfradiopro
Thanks for the quick response, Tarbat....I look forward to trying it out this evening.
Dave
Brian
A local person made this edited version with a 'sorting' feature on the html report page.
It uses 2 separate files for the CSS and script which the template then
links to (must be in same folder as the report output) on your server.
So go test it out!  I been using it the past few weeks and I like the sorting feature on the html reports.  Since you can sort it out by aircrafts, airlines, etc...
Maybe when Tarbat updates the 'RunSQL.zip' versions.  He can add this feature to the new releases.
Extra Link:
The source for the sorting came from this website.
http://www.cssjuice.com/16-sortable-table-techniques/
*Download the file below*
John Racars
Quote from: tarbat on February 27, 2009, 06:38:43 PMThen run the sql.bat file.
Hi Tarbat,
I did do so. After running the BAT-file the DOS-screen apear shortly and that all. Nothing happens, no report.
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Brian
John,
Make sure you are adding the files in the "AirNav RadarBox 2009" folder on your XP computer.  Then run it from that location.  Any other folder directory wont work without changing some code lines first.
John Racars
Hi Brian,
Thank you. I did as Tarbat described. After restarting my PC all is working verry well so it looks.
"report.htm" was made!
13 NM East of EHAM
ANRB:
frogger
Hi Tarbat!
I am using this script for my todays logs. I have now some questions, hopefully you can answer this:
- I want to export all logs ever registeterd. What must I write into the sql.txt? Now there stands for 2011:
WHERE
   substr(Flights.EndTime,1,4)="2011"
- I am only interested in this topics of the Database for export: Reg, Airline, Aircraft, End Altitude, Flight Ended.
How can I export this? My complete sql.txt is this one:
.output radarbox-log.htm
.mode list
.header OFF
SELECT DISTINCT "<html><head><title>Radarbox Report today</title><body><link rel=stylesheet href=stylesheet-table.css type=text/css \><script src=sorttable.js></script><table class=sortable>" AS FIELD_1 FROM Aircraft;
.mode html
.header ON
SELECT DISTINCT
  Flights.StartAltitude AS "Start Altitude",
  Flights.EndAltitude AS "End Altitude",
FROM
Aircraft
WHERE
ORDER BY
  Flights.EndTime,
  Aircraft.ModeS;
.mode list
.header OFF
SELECT DISTINCT "</table></body></html>" AS FIELD_1 FROM Aircraft;
.exit
- Is it possible to export these data (Reg, Airline, Aircraft, End Altitude, Flight Ended) direct to csv?
frogger
Could no One help me with my questions?
Thank you for your help.
#26
Quote from: frogger on November 09, 2011, 09:18:20 AM- I want to export all logs ever registeterd.
Simply remove the WHERE statements:
WHERE
Or, in MyLog, use MENU - EXPORT TO CSV
frogger
Thank you Tarbat, now with deleting the WHERE-Satements, it exports more logs. But about a half of the logs were without the Flight Ended Date, the oldest Flight ended Date in my log was from the 8th November.
My Log in the radarbox-Software shows me older entries from september. This was not exported or without the Flight Ended-Data.
Why?
Wen I choose in MyLog Export to csv, it exports all mylog-data, but without the Flight end Time and the last altitude. Can I export this data also with MyLog or only with the SQL-Export above?
#28
Quote from: frogger on November 13, 2011, 11:03:54 AMThank you Tarbat, now with deleting the WHERE-Satements, it exports more logs. But about a half of the logs were without the Flight Ended Date, the oldest Flight ended Date in my log was from the 8th November.
Okay, to get older flights you'll need to access the FlightsOld table as well.  You can do this using the VIEW called v_Flights, which is:
SELECT * FROM Flights UNION ALL SELECT * FROM FlightsOld
I would suggest using an SQLite database tool if you're wanting to do this level of data extraction.  I use SQLite Maestro, but others are available.
If you simply want to dump ALL the flights data from ALL time, then use this query:
SELECT DISTINCT
  v_Flights.Registration,
  v_Flights.EndTime,
  v_Flights.Callsign,
  v_Flights.Route,
  v_Flights.StartAltitude,
  v_Flights.EndAltitude,
  v_Flights.MsgCount,
  v_Flights.ModeS
FROM
v_Flights
ORDER BY
  v_Flights.EndTime,
  v_Flights.ModeS
frogger
Thank you again Tarbat, the query works perfect.
Now another question, hopefully you can answer it:
I have executed the query and I would like to have another table within the results: the table airline.
How looks the query within the data for the airline-name?
