Alerts system query.
Started by DAFO1711, March 04, 2009, 05:05:51 PM
Tramline
Quote from: tarbat on March 06, 2009, 03:35:44 PM
Quote from: Tramline on March 06, 2009, 02:29:35 PMSince around 10:00 I've had 540 alerts whilst on 'my flights' but during 45 mins of linking upto the 'Network' I only received 12 alerts.   There is definately a problem when using alerts and connected to the 'Network'
A known problem.  If you have network aircraft turned ON, and network alerts turned OFF, then if an aircraft first appears in the network list, it will not alert, even when that aircraft transitions to the local list.
Other problems associated with aircraft transitioning between the network and local list also occur - missing routes, for example.
I hope that these problems will be sorted out with the new update.  The alert function IMHO is potentially the best feature of RB and the main reason I bought it.
Still very impressed with the system, the support and the forum members friendly and helpful attitude to all users.
Located 2 miles South of LHR.
