Populating Untitled
Started by kdt1, April 09, 2009, 06:34:09 PM
jgrloit
Airnav..
Would it be possible to incorporate a file to be used when offline to list Mode-S ID's that require information, that could be used when next online to update the databases with details from the 'missing' aircraft?
If it was a simlpe list it could also be created externally to prompt for new information - from a search of a DB table for an airline that has ceased to trade, as an example  - to update the new owners!!!
Based in Hexham - Tyne Valley
kdt1
jgrloit ,
I too tried the above - and the LK field was replaced.
ACW367,
The AC issue you have is then beyond the control of Airnet.
Not true, they just need to rethink there approach.
Great Ideas jgrloit!
EGNXR
Hi all,
Just checked through todays untitled 36 in total. Of those 12 did not have a picture.
So checked Airnet and a photo was available for every one which means it had updated the the database and written a link for 2 photos in LK & LK2 but had not downloaded the picture. So I would guess there is a problem with the photo download feature.
Airnav is this your end or mine. pls advise:-)
Have now manually updated pictures to RB
Cheers John
Based in Derby 5Nm NW of EGNX
kdt1
Support,
I am still in limbo on this populating untitled Issue, Any new thoughts.
kdt1
AirNav Support, AirNav Development
Any new thoughts?
Do you mean in terms of it being over written by the database or for us to try and get the company details instead of untitled?
kdt1
Pretty much all of the above!
Sorry I think we missed out adding a picture for the aircraft as well (create a pic in the photo directory of its registration e.g G-BOAF.jpg) This and LK having information will mean it won't try and overwrite it.
Regarding getting data from Airliners we are trying to change some of the logic so that if it does find Untitled in the company name we only take the information between the brackets. E.g Untitled (ABC Company), so in theory it shows ABC Company. If there is no brackets then Untiled is used.
kdt1
Where it stands now for me and a few others this is such a huge pain in the ass.
I guess as long as your are working on a better solution, that's all I can ask for at this point.
kdt1
Support,
Question, your data base is not in sink with GAS, for
a lot of US aircraft.
Is the problem coming from you guys or GAS.
The issue does rely in the syc.
As our main database is what RB connects to, if its not our database it gets the record from GAS and updates the main database.
The issue lies in whether we can work out a way that each entry in the database is the rechecked in GAS without causing GAS to crumble under the load and still keep it similiar.
kdt1
Can't you have your data base check for missing untitled?
Or would that be to much for GAS severs to handle?
Do you think there setup is not friendly enough to just
get the basic info.
I guess you can tell this is still a daily pain and is just
turning my hobby and others into a real bummer.
Can you tell GAS to get on the same page?
Untitled issue has nothing to do with GAS. The Untitled data is picked by via airliners.net
We can either start using only GAS data but then GAS is not brilliant outside Europe. When something is not in our main database or GAS we look up using airliners.net and thats where this Untitled issue comes in.
In theory this is what we need:
- Main Database (which RB connects too)
If Not in Main Database look up in GAS and add to Main. If not in GAS look at airliners.net and add to Database (with Untitled fix).
Every x days record is rechecked with GAS and updated to GAS record.
kdt1
#28
So why can I get the right data from Gas and it is not on your
severs?
Support
I appreciate you taking the time to explain.
I am having a hard time getting my brain around your
answers.
jgrloit
Support
Following on from your theory, how would the individual systems request, updates?
Would they be 'forced' down the links, or would users need to run some kind of populate/ update request?
For Airlines - could wrong flight ID's v Company names via Airlines table be used?
Is the Airlines table updated automatically?
Also how are the Routes i the table being updated?
Thanks.
