Creating Airport Outlines
Started by Allocator, October 07, 2007, 08:09:19 AM
igsr13
OK,
i try LIEA.out and i will advise.
I finish the outlines of Athens airport but i can not see it.  I will send it as attachment to check it.
igsr13
No not possible to see even LIEA :-(
I try all colours all zoom posibilities.
Confirm which folder you have placed in the .out file in?
igsr13
Yes,
that is correct.  On this path:
C:\Program Files\AirNav Systems\AirNav RadarBox 2007\Out
#19
Quote from: igsr13 on December 04, 2007, 06:05:43 PM
Yes,
Got it!
You're putting the .out files in the wrong directory!
The correct directory is
C:\Program Files\AirNav Systems\AirNav RadarBox 2007\Outlines
that's Outlines not Out - as I said at the start of this post :-)
Quote10. Save the NotePad file as an .out file (for example EDDH.out) to the /AirNav RadarBox 2007/Outlines directory.  Make sure that the file is saved as .out and not .txt or .out.txt
igsr13
OK i can see everything now!!!!!
Some more help please.  On full zoon there is a variation of the aircraft possition and the drawing (outlines).  How can i adjust/calibrate it?
Elliott
davis
yes, the folder Outlines must be created!
P.S. Allocator is a pleasure to know that you were in Sardinia, i was a pilot of taxi flight in Alghero for 20 years from 1968. Some times during school flight of Alghero Aeroclub from Alghero to Cagliari we swapped Decimo for Cagliari and only on short final we undestand the error lokking for military aircraft on the apron :D  :D i talk about 1970 when it was possible to do this kind of error! :)
