Another poorly Radarbox
Started by John Hargreaves, June 07, 2009, 04:15:16 PM
BOM1
Thanks for the advice and reassurance guys.  I've been using the supplied antenna outside on my balcony (13th floor) during the good weather but have now brought it in as a precaution.  To be fair, my previous box, which met it's demise after falling from a window ledge, survived last years monsoon with the aerial outside throughout.
Steve
flightchecker
#31
QuoteI've been using the supplied antenna outside on my balcony (13th floor) during the good weather but have now brought it in as a precaution.
It won"t look like a beauty anymore Steve, but why not put the antenna in a plastic bag, let the coax run out of the bag with some sealing tape wrapped around it, thus making the antenna almost weatherproof.
If you could "afford" a lucid bag, you might even throw a glance on it's "precious" content  from time to time if desired.
I'm joking, but to be honest of course: not a too bad idea to beware the default antenna of harsh weather.
Karl
Fenris
Quote from: AirNav Development on June 07, 2009, 08:17:55 PM
Serial Numbers:
000001 to 01750: 37 units returned and repaired on a total of 1750 (2.1% of the units). Units over S/N 101500 are protected against static.
10001 to 15000: 2 units returned on a total of 3000 sold. (0.07% return rate).
A quick question for you. If a box in the pre-S/N101500 range is returned because of a static-related failure, is it repaired to the new standard?
Sorry, been out of RB loop for a while and have not had a chance to catch up the other threads.
snowman
This may be a silly question but only having had my radarbox for about a week (s/n 10954) how can you tell if it's not working properly
It's a bit like eyesight - how do you know if you can see as well as others?
It all depends on location but I would say taking my worst direction from a bedroom window, I would want over 30 miles. Best direction - sky is the limit.
If you're down to less than 10 you maybe need a check out.
Pleas read below:
http://www.airnavsystems.com/forum/index.php?topic=2759.0
We are locking some of these topics now as its been discussed a lot and we have FAQ for it now and also certain customers keep coming up with silly theories even after we have answered them.
