Author Topic: Pharology  (Read 13489 times)
Brimon
Re: Pharology
« Reply #15 on: June 12, 2009, 07:39:11 AM »
Businesswise we use this site for ship tracking ,probably well known to those on here.
http://www.shipais.com/
and this for ship info
http://www.vesseltracker.com/app
Chasing the heavies from a secret bunker in Scotland
Re: Pharology
« Reply #16 on: July 04, 2009, 12:54:52 PM »
This made it into our local magazine, the Tarbat Crack.
[attachment deleted by admin]
Re: Pharology
« Reply #17 on: July 04, 2009, 12:58:16 PM »
Airnav, any chance that ShipTrax will be release within the next month?
I've been asked to do an article on the kit behind aircraft and ship tracking as well.  Would be good to get a screenshot of ShipTrax covering the Moray and Dornoch Firths for the article.
TedLoon
Re: Pharology
« Reply #18 on: July 04, 2009, 05:48:03 PM »
outstanding malc
nice story btw tarbat
GlynH
Re: Pharology
« Reply #19 on: July 05, 2009, 07:07:40 PM »
Much more than only that. Anyway we cannot talk about it. Confidential.
But you already have! ;^)
Ethernet interface...very high on my list...most everything here is networked from the usual PC/Laptops/HTPC/Server/Printers etc. through 3 x UPS, CCTV, Telephone system and even my AV Amp.
To be able to sit my RBII on the end of an ethernet cable as close to the antenna as possible and well away from interference (and hopefully access it directly from any PC in the house - multi-user maybe - remote user perhaps?) would be absolutely terrific!
If you go down the ethernet route could you please make it support Power over Ethernet as my managed switch is PoE capable - I use it for a single Cat5 connection to IP cameras - easy.
As an example the total PoE available here is 180w spread over 24 ports but I believe it will deliver a maximum of 15.4w per port.
Oh and please fit a proper N-type socket for the antenna connection so there is no need to use adaptors.
And allow for some type of bracket/cradle/mounting feet or some other way of mounting it to the wall.
And an on/off switch and a way to turn off the LED's.
Thank you...and if you want a Bete tester all you have to do is ask! :-)
Kind regards,
-=Glyn=-
peteeds
  • RADIO AMATEUR (2W1FJZ - MW3PET )
Re: Pharology
« Reply #20 on: July 06, 2009, 05:30:15 PM »
Brimon, thanks for the link into Shipais, did not know it existed. Fantastic site. If airnav shiptrack is anything as good as this then roll on.
Cheers  Pete 2W1FJZ
Re: Pharology
« Reply #21 on: July 06, 2009, 06:36:28 PM »
Another good marine AIS tracking site is http://www.marinetraffic.com/
peteeds
Re: Pharology
« Reply #22 on: July 06, 2009, 07:10:28 PM »
Thanks for that one Tarbat, Both in my favourites, Can't wait for Airnavs new shiptrax system to be launched, sounds & looks very interesting.
Cheers Pete.
