Author Topic: Vulcan's up!  (Read 46743 times)
EMA
Re: Vulcan's up!
« Reply #30 on: June 23, 2009, 10:53:36 AM »
If you remember the operational displays of the Vulcan then you will be disappointed with what it is allowed to do in civil hands today but at least it is still flying.
malc41
  • RadarBox Beta Testers
Re: Vulcan's up!
« Reply #31 on: June 23, 2009, 11:15:14 AM »
Remember them being a Waddington. was down there on exercise, and it was very impressive when one of them scrambled
15 Miles East of EGNJ
EMA
Re: Vulcan's up!
« Reply #32 on: June 23, 2009, 11:24:32 AM »
I used to visit most of the V bases and remember a 6 vulcan scramble from Waddo in the late 70's a very impressive sight.
bearcat
Re: Vulcan's up!
« Reply #33 on: June 23, 2009, 11:53:34 AM »
I can remember, as a lad,the old Finningley Air Shows when they used to scramble 4 Vulcans to open their air shows with thier steep climb outs and turns. The ground just seemed to tremble.
Nobody seemed to worry about costs then.
malc41
Re: Vulcan's up!
« Reply #34 on: June 23, 2009, 01:24:38 PM »
That was when petrol was 20p a gallon and aviation fuel was a give away!!!
EMA
Re: Vulcan's up!
« Reply #35 on: June 23, 2009, 01:57:20 PM »
Pre decimalisation 4 shillings.
EMA
Re: Vulcan's up!
« Reply #36 on: June 23, 2009, 01:58:33 PM »
There was always a Vulcan at Finningley BoB days, great times!
malc41
Re: Vulcan's up!
« Reply #37 on: June 23, 2009, 02:08:16 PM »
EMA
Absolutely right, what will it be when we use the Euro?
EMA
Re: Vulcan's up!
« Reply #38 on: June 23, 2009, 02:16:34 PM »
EMA
The End...................
EMA
Re: Vulcan's up!
« Reply #39 on: June 23, 2009, 02:18:45 PM »
Just after the Falklands the RAF used two vulcan display aircraft XH558 and XL426 both used callsign Vulcan01 during air displays.
malc41
Re: Vulcan's up!
« Reply #40 on: June 23, 2009, 02:35:03 PM »
EMA
So True......
Re: Vulcan's up!
« Reply #41 on: June 23, 2009, 02:48:56 PM »
never seen anything that big doing aerobatic  type maneuvers.....the image of has remained with me since ............
Rather than the image, it's the sound of those engines howling gets my blood pumping, as for the prototype and pre-production Concorde Olympus 593s, quite something else again!    Where I live, it used to be fantastic hearing the Concordes coming home (UK and French) every evening - now sadly missed by thousands.
GlynH
Re: Vulcan's up!
« Reply #42 on: June 27, 2009, 01:00:30 PM »
She's up again...14.40 display at Biggin, 15.30 possible practice display at Lyneham, 15.50ish return to Brize Norton according to Twitter.
-=Glyn=-
fatkat
Re: Vulcan's up!
« Reply #43 on: June 27, 2009, 01:53:19 PM »
how best to track on network ?
registration = XH558
Re: Vulcan's up!
« Reply #44 on: June 27, 2009, 02:01:37 PM »
Not necessarily - GAS has the Vulcan in its database as G-VLCN (which is correct as this is it's current registration), so if your database is autopopulated by GAS rather than manually edited to have XH558 as the registration, then looking for XH558 in the list or by setting an Alert isn't going to work.
If you use the Hex code 40109F then you can't go wrong, as this will show even if you don't have the Vulcan's data in your NavData.db3 database.
It's worth looking in MyLog to see if you already have 40109F as you might have picked up the Vulcan without realising it :-)
And of course, the Vulcan will only show up in MyFlights, not via the Network, as it doesn't transmit position information :-(
