Author Topic: Future Version Suggestions / Requests  (Read 272834 times)
air7677
Re: Future Version Suggestions / Requests
« Reply #300 on: July 10, 2010, 02:48:58 AM »
Alan - I think snowman means the aircraft labels on the map, not the column grids. He's not alone in wanting that!
[/quote)
 i would like this to
Aerotower
« Reply #301 on: January 22, 2011, 05:30:53 PM »
AirNav Development,
It is possible a future version (preferably at the next) appear which is red in the image attached?
Aircraft that are not in the database is possible to know which aircraft is only with the squawk code.
Can answer whether it is possible? please?!
« Last Edit: January 22, 2011, 06:46:43 PM by Aerotower »
73TORANA!
« Reply #302 on: January 24, 2011, 02:03:35 AM »
Save settings on shut down I think would be a must and a new chair ,this one has a dud spring.
Aerotower
« Reply #303 on: January 24, 2011, 12:18:18 PM »
I would like the facility to playback recordings at an accelerated rate so I can quickly scan planes that passed near my location throughout the day while I was away and then switch back to live realtime tracking.
This would be an excellent idea.
A rewind and go forward. Please add this to the next version.
But also about the possibility of watching what was recorded but keeping what is happening (LIVE) behind.
Brimon
« Reply #304 on: January 26, 2011, 08:59:30 AM »
My personal wish list:
Rotatable maps to allow alignment with view out of my window.
Dual screen spreding , map on one interface on other.
Ability to resize sections of the interface & if necessary move bits around.
Fade away scroll bars, they disappear after a set period & activated by clicking on screen.
Ability to resize colums, or at least an autofit option.
A working option to save the screen set up on exit.
I love my Radarbox,but would marry it if these issues were ironed out.
Chasing the heavies from a secret bunker in Scotland
Chris11
« Reply #305 on: January 26, 2011, 02:36:08 PM »
Mine is a fairly simple one - the ability to accept or reject updates from the network. Not like the current all or nothing ability.
Could even be the creation of a temp file with all the updates and you could select a yes or no and then run an update routine
ACW367
« Reply #306 on: January 28, 2011, 01:17:28 AM »
Mine is exceptionally simple.  A fully bug free version 3.13 and 4.03 with up to date silhouettes, flags, Navdata, D008.dat and GE Models for every type currently picked up ADS-B on the network.
Preferably with the ability for new buyers of the system to get these installed on first start up of their brand new machines.
    • Rod's RadarBox Downloads
« Reply #307 on: January 28, 2011, 01:34:00 AM »
And include the 64-bit drivers in the package.
ACW367
« Reply #308 on: January 28, 2011, 01:45:47 AM »
« Reply #309 on: January 29, 2011, 06:30:31 AM »
The simplest things are usually the hardest to achieve... ;-)
(Sorry, but I couldn't resist...)
PatW
« Reply #310 on: January 30, 2011, 12:42:38 AM »
I have my ADU database and Airnav linked so that I can use ADU to regularly update the airnav database, this also adds 'seen' into the comments column of 'My Log' for all that I have seen as logged in ADU.  Can the an additional column be added into the main grid next to the map screen for thi8s purpose.
Darth Radar
  • Trust the Dark Side
« Reply #311 on: January 30, 2011, 08:48:03 AM »
That should be easy enough. I'm sure Airnav will look into it and do something about it immediatly after ShipTrax has been released - but don't hold your breath!!
Teejay
airdata
    • Airdata
« Reply #312 on: February 09, 2011, 01:08:22 AM »
Hi Airnav
I hope the equator bugs and aircraft dropping off the screen bugs are fixed with the new release.
It would be great if there was a way to export data from an Access database into db3 format that radarbox uses.  That way one can update data much quicker than one cell at a time.  I guess the new aircraft database is a improvement as long as there are regular releases.
Mark
Under the flight path, 5NM from runway 23L threshold at Auckland (NZAA), New Zealand.
chewycanes
« Reply #313 on: February 10, 2011, 12:20:36 PM »
Airnav
This was discussed on a separate post but i did not want it to get lost when you do updates.
It relates to Alerts.
a) If an alert occurs for a specific aircraft and then another other detection of that same aircraft occurs during the day no alert occurs.
Possible solution:- Allow a selective timeout so the user decides how long before a second alert can occur with a minimum set so as not to get multiple alerts due to aircaft going behind obstructions.
b) The Alert log displays only filght ID and ModeS.
Possible solution:- Add time of alert.
Brian
« Reply #314 on: February 13, 2011, 05:41:26 PM »
Another addition to the long requests list about alerts - could we have an alert that happens when we get returns from within a specified distance of a specified airport or lat/long apart from home?
That way we can get alerts when a particular location comes up on the network.
