Author Topic: WOW! Myflights up:-)  (Read 24247 times)
Re: WOW! Myflights up:-)
« Reply #15 on: June 22, 2009, 11:04:19 AM »
Did you change your settings in preferances like tarbat did, to 110/790
If you did, it would be showing more flights, in the total box at the top.
If you do extend your timeouts to 15 minutes, then it's advisable to also set a Quick Filter on MyFlights of Status <> 1Timeout
John Racars
« Reply #16 on: June 22, 2009, 11:06:43 AM »
Normally max out at about 105 at peak times.
How good is that:-)
Hi All,
With me, after installing V3.0 last friday, I have seen over 300 at peaktimes.
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
titigti
« Reply #17 on: June 22, 2009, 11:27:44 AM »
How good is that:-)
Hi All,
Hi John
Same here for me 300+
Mylog for sunday till 22:00  2985 airplanes :)
Greetings,
Etienne
www.liveais.nl
malc41
  • RadarBox Beta Testers
« Reply #18 on: June 22, 2009, 04:11:10 PM »
abrad41
Yes my initial thoughts were that I had increased my capture by 150-200 then As you say looked at the duplicates in mylog :-(
15 Miles East of EGNJ
aps
« Reply #19 on: June 22, 2009, 07:44:18 PM »
aps
Hi , no i didnt do that yet ...
cheers Tony
aps
« Reply #20 on: June 22, 2009, 07:45:57 PM »
How good is that:-)
Hi All,
Hi John
Greetings,
Etienne
www.liveais.nl
Yes , i have seen a big improvment in a/c received also .
Tony
Manuel Mendes
    • Manuel Brito Photography
« Reply #21 on: June 22, 2009, 09:58:37 PM »
I like how it works now. Yesterday if I used version 2.0 I wold have 500 aircraft but I used V3.0 Beta and I had 1096 airplanes :-) Nice.
t1mb0
« Reply #22 on: June 23, 2009, 09:43:24 AM »
my MyFlights peaked at 210 just before I left for work this morning.
12m SE of EGHI
atcukmatty
« Reply #23 on: June 29, 2009, 08:42:09 PM »
what is the Msgs/sec?
t1mb0
« Reply #24 on: July 01, 2009, 06:32:21 AM »
had a quick look this morning, 789 Msgs/Sec(146), not its busiest time though
12m SE of EGHI
« Reply #25 on: July 01, 2009, 10:38:29 AM »
Can you explain what you mean ?
V3.0 has lots of enhancements, but I can't see any that would account for you picking up any more aircraft than you did before, let alone double the number.
« Reply #26 on: July 01, 2009, 11:03:32 AM »
I think he might be confused with the network flights.
« Reply #27 on: July 01, 2009, 04:09:55 PM »
V3.0 decodes more mode-s frames which results in more flight numbers being shown. In areas where there are a lot of mode-s only aircraft (no ADS-B) the number of aircraft received can double.
« Reply #28 on: July 01, 2009, 04:53:07 PM »
Yes, I understand that part - RadarBox displays some Flight IDs for non-ADS-B aircraft where previously you would see an aircraft without one.
But I'm having problems making sense of this.  Surely you're not saying that some non-ADS-B (Mode S only) aircraft didn't appear on RadarBox in previous versions, but do now?
So exactly which category of aircraft do any newly-displayed additional ones fall into?
« Reply #29 on: July 02, 2009, 06:19:49 AM »
Come on AirNav, you can't just leave this unanswered.
Consider.  If the competition came out with a new version of their software and claimed that it could result in up to twice the number of aircraft being picked up compared to previous versions, then you (and I) would want to understand how that can be, and we would be justifiably critical if they failed to back it up with facts.
Making a statement like
but failing to explain where these additional aircraft are coming from sounds a bit like snake oil to me.
Looking at the published list of V3.0 enhancements I can't see anything that would account for this - have you left something out?  Granted, you are now decoding BDS2,0 frames which will allow you to display more flight IDs where previously flights would have been displayed with that field blank, but that's a completely different issue.
So allow me to ask again, what's the basis for the assertion that "the number of aircraft received can double" (or even increase at all) with V3.0?
