Settings not saved after restart
Started by Harry, July 02, 2009, 07:37:44 AM
vonsmalhausen
Quote from: XR220 on July 03, 2009, 08:45:34 AM
Can we also make sure the software remembers your personal colour settings after shutdown. I regularly have to go to Map / Colours to reset the aircraft colours on the map to my own settings.
Jim
same problem here
I agree AirNav should fix this, but as I've said in another thread, a workround that works for me is to rename your preferred colour scheme as Real Radar.mcl, which is the one it seems to want to load.
malc41
Thanks Rod
thought someone would have a workround
15 Miles East of EGNJ
atcukmatty
ive noticed airnav software crashes once the computer is locked. Can this be fixed?
Quote from: atcukmatty on July 03, 2009, 09:43:10 PMive noticed airnav software crashes once the computer is locked. Can this be fixed?
What do you mean by "locked"?  I regularly use both standby and hibernate, and Radarbox resume perfectly afterwards.
abrad41
I get a problem with closing down after the RB has been running a while.
I go to close it down in the normal way, it then leave its sitting in the task bar doing nothing, if I open it again from task bar it shows just the menu's and all grey in the centre were the map and listing should be.  If I force it to close with ctrl/alt/del then I get the crash/error message.  This also was happening in v.2.1. I have sent the problem to support.
Andy
Quote from: tarbat on July 03, 2009, 10:04:57 PM
Windows key+L ?
