FTP upload does not overwrite
Started by jonjorobb, July 03, 2009, 07:26:48 PM
abrad41
Thank you mate.
But, should it be loadeding a upto date one in the screen shots folder.
You now mate, I am just trying everything I can think of. I have been speaking to my ISP about the problem and they have never indicated they have a upload limit.  I have also been with this ISP about 6 to 7 years and never had a problem when I first had the RB.
I would try a alternative provider, but I am just trying to get it to work within my own website, which I may add was always working before. If I was to use a alternative provider the ftp upload would be away from my main site.
Andy
abrad41
if you look at your ftp now you are on facebook, covering your map.
Andy
abrad41
Thank you, I have been watching your site and you have proved your point.  I will now have to get onto my ISP.
Thank you again
Andy
#33
Yes, the wife decided to use Facebook :(
Anyway, it ran for 2 hours uploading fine.  I would say that on the previous ftp provider I used (Geocities I think), I used to get exactly the same problems.  It would upload for a while, then stop.  That was caused by an upload limit.
Just thought it might be worth trying an alternative provider to eliminate your PC setup from the problem.
Good luck!
EDIT: Previous thread about the problems I had with FTP to Geocities - http://www.airnavsystems.com/forum/index.php?topic=1414.msg16009#msg16009
jonjorobb
I've took your advice tarbat and I now have a fully working FTP upload with a site I have created with gofreeserve :) .
Thanks,
Jonjo
abrad41
Jonjo Robb
I also took tarbat's advice and I now have a fully working FTP upload with gofreeserve.
www.absbta2009.co.uk
Andy
The link works fine for me - can't see any aircraft though at the moment, just the map.
