Monitor suggestions?
Started by tarbat, July 10, 2009, 01:47:39 PM
Quote from: atcukmatty on July 10, 2009, 10:00:18 PMWhere did you download your airways from? (http://www.homepages.mcb.net/bones/Kinetic/Utilities/Kinetic_Utilities2_Outlines.htm)?
The airways are just the standard ones in Radarbox.  Other things such as coastline, danger areas, etc. are from the Bones site.
atcukmatty
ok, is it possible to turn those on and off? or do you just have to delete them from the outlines folder
If you mean individually, yes - the only way is to remove them from the outlines folder. You can of course turn them all off and on using the Map...Outlines menu command.
colinhall
Morning Rod. Very good to see your July 10. How do you get the two maps (ie airport and map) on to one screen like you have please.Colin.
Hi Colin
Just open another map (Map...Open/Save and if you want, chose the default map or any other one).
Then choose Window...Tile and choose Vertical or Horizontal.
You treat each map individually, with different colours, satellite overlays, etc. Just click on the map you want to change before you change it.
I'm not sure how well this worked in V2 - I'm using the closed beta version and it works a treat!
