Author Topic: Network  (Read 8664 times)
itestoo
    • Radarvirtuel
Re: Network
« Reply #15 on: July 12, 2009, 01:08:23 PM »
it works for instance
thank's
Laurent
Canonjohns40D
Re: Network
« Reply #16 on: July 12, 2009, 01:31:21 PM »
Hi Airnav for information. I am seeing Network traffic at 13.30utc on my box, however the network box at the bottom of the screen is yellow. Any thoughts?
John
Re: Network
« Reply #17 on: July 12, 2009, 01:35:13 PM »
John
John,
I don't think that you will be seeing network traffic if the light is yellow.  Are the aircraft moving?  Do you have preferences set to show '*' after the callsign?
You might just have the 'ghosts' of the network tracks showing after the last failure?
Canonjohns40D
Re: Network
« Reply #18 on: July 12, 2009, 01:37:24 PM »
Cheers you are spot on as they have all gone now just thought it was an unusual occurrence. Thanks.
John
John Racars
Re: Network
« Reply #19 on: July 12, 2009, 02:00:06 PM »
Hi John,
Same situation with me from time to time. I think that you did not see that the light becomes "green" for a verry short while. When the light become "green" for a shortwile networkflights appears on the map. There after, when the light becomes "yellow" again all the network flights disappears after a few minutes.
Normaly, when the light is red or yellow, no networkflights can be seen.
« Last Edit: July 12, 2009, 02:04:33 PM by John Racars »
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Re: Network
« Reply #20 on: July 12, 2009, 02:49:34 PM »
We are still having some problems with our RadarBox server flight data engine. We have 2 members of our team working on this problem so the server could continue to be up and down during the next 4 hours. Pls accept our apologies. We will do our best to have this sorted out asap. We will keep you informed.
John Racars
Re: Network
« Reply #21 on: July 12, 2009, 07:05:02 PM »
Hi Support & All,
Now it looks all is working correctly again with me. Thanks to Support for the fast solving this problem!!!
13 NM East of EHAM
ANRB:
FlyOverMe
Re: Network
« Reply #22 on: July 12, 2009, 10:36:38 PM »
Network downtime was only for a short while. Thanks for sorting this out Support. Great response, thankyou. <-- I meant to post this earlier.
