Author Topic: No reg No aircraft  (Read 7720 times)
vassylad
Re: No reg No aircraft
« Reply #15 on: July 18, 2009, 05:28:22 PM »
Hi Allocator  I put Airnav into the following directory C:\Programs\airnav all is well, so the next question is when I upgrade to V3 from V2 do I use the default directory or the same one as above or another one?
Sorry for all the daft questions.
Michael
« Reply #16 on: July 18, 2009, 05:36:25 PM »
Michael,
For V3.0 Beta, why not use C:\Programs\airnavV3 then you can have both versions installed at the same time in case you want to go back to V2
Again, don't do an upgrade, do a full install from the install.exe you downloaded earlier.
