Author Topic: RELEASED - AirNav RadarBox 2009 - 3.01 Beta  (Read 181384 times)
Harry
Re: RELEASED - AirNav RadarBox 2009 - 3.01 Beta
« Reply #90 on: July 26, 2009, 08:36:04 AM »
I own that server. There are more people uploading stuff to my website daily and there is  no limit on the ftp.
I will try it to one of my ohter websites.
FTP is still generating _200907260505.tmp files without renaming to an another name. There are a lot of .tmp files  in the folder right  now. Any suggestions?
Who is your FTP provider - do they have any FTP upload limits?  Others have solved this problem by switching to another FTP provider - try gofreeserve.
« Reply #91 on: July 26, 2009, 08:38:28 AM »
What's the ftp server software?  Does it support renaming of files via. ftp?
See http://www.airnavsystems.com/forum/index.php?topic=3000.msg27562#msg27562
Harry
« Reply #92 on: July 26, 2009, 08:39:52 AM »
While checking my FTP settings I noticed that after a few click on the File menu option I'm not able to open the File menu option anymore. (all others are a no go too). I have to kill the radarbox application via the  task manager.
when I click on one of the menu options it seems they are selected, but they won't open.
Rural Outpost
  • Still waiting to pick up a DAN AIR HS748 !
« Reply #93 on: July 26, 2009, 10:15:38 AM »
I have jst down loaded 3.01beta version and all looks good so thanks airnav. However I can't find how to mark home with a cross. Can some one tell me what I haven't done.
« Reply #94 on: July 26, 2009, 10:25:44 AM »
Use:
File > Preferences > Home Station Data
Put your home position in the Latitude and Longitude boxes (in decimal degrees)
In Preferences > RadarBox, make sure that you have 'Draw Home Location Legend' ticked.
Rural Outpost
« Reply #95 on: July 26, 2009, 10:33:36 AM »
I hadn't ticked Draw Home Location Legend box. Thanks allocator
Harry
« Reply #96 on: July 26, 2009, 11:00:44 AM »
Used two different sites, but still no luck. I'm only getting .tmp files.
« Reply #97 on: July 26, 2009, 11:33:22 AM »
As tarbat says, this is almost certainly a limitation of the host rather than of the FTP upload.  I presume that it's some kind of safety mechanism to stop files being overwritten.
You could try to manually FTP files of the same name to the directory where you want to save the RB screenshots and see what happens?  Do you get tmp files created in this instance, or does the new file just overwrite the old one without any problem?
« Reply #98 on: July 26, 2009, 02:08:32 PM »
Have you tried www.gofreeserve.com .  If it works okay with gofreeserve, then you'll know for sure that it's a problem with your ftp host, and not a problem with Radarbox.
abrad41
« Reply #99 on: July 26, 2009, 03:07:52 PM »
Harry
I had all the problems below -
Quote
The username which I use for FTP  have full access to the webserver.
Quote
Quote from: Harry on Today at 11:00:44
Quote from: tarbat on Today at 08:38:28
But tarbat pointed me towards gofreeserve and now everything is working great. You should try it just for your own satisfaction.
www.absbta2009.co.uk have a look you will see it
Andy
Jeremy
  • Jeremy
« Reply #100 on: July 26, 2009, 03:22:27 PM »
Andy,
How did you get your aircraft to fly backwards like that??
J.
G4DOQ
QRZ.com
« Reply #101 on: July 26, 2009, 03:24:04 PM »
Andy,
J.
They're not flying backwards, Andy has got path vectors on and trail lines set to zero :-)
Jeremy
  • Jeremy
« Reply #102 on: July 26, 2009, 03:25:22 PM »
Sorry Allocator - my sense of humour!
J.
G4DOQ
QRZ.com
« Reply #103 on: July 26, 2009, 03:29:39 PM »
I did wonder .......... got me! - lol
abrad41
« Reply #104 on: July 26, 2009, 04:05:31 PM »
Jeremy
What a sense of humour -
If you look in the next 5 mins or so they will be moving forward I hope.
Andy
