Author Topic: Planeplotter problem  (Read 11974 times)
DoctorM
Re: Planeplotter problem
« Reply #15 on: August 22, 2009, 01:20:15 PM »
I have PP on now, user AW, UAE.
I have 2 aircraft showing regs, out of about 30 - so it must be working, but not for all. it just says No-reg.
Aircraft types arent showing either, not sure if they do on PP.
Doc
DoctorM
« Reply #16 on: August 22, 2009, 01:24:34 PM »
I wonder if ther are there any settings i need to change on the RB setup bar the start record?
« Reply #17 on: August 22, 2009, 03:00:44 PM »
Does that mean you're using the RB log instead of port 7879?  If you're using port 7879, you don't need to start recording in RB.  Try it without starting record in RB.
viking9
    • Aircraft Photography
« Reply #18 on: August 22, 2009, 03:03:50 PM »
DoctorM,
Make sure that you minimise the map so that the whole of the area you are intersted in is showing.
I suggest that you join the Planeplotter group. Then download the latest basestation.sqb file. It is very well populated.
Have you selected 'View' 'All Aircraft'?
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
« Reply #19 on: August 22, 2009, 03:05:15 PM »
I thought we were talking about the callsign being missing, not the REGISTRATION.  To get registrations, you'll need a basestation.sqb.
viking9
« Reply #20 on: August 22, 2009, 03:08:15 PM »
DoctorM, are you in the UAE? Switch on sharing and I'll see if I can see your station.
Tom
15 miles SE of EGUN
DoctorM
« Reply #21 on: August 22, 2009, 03:11:54 PM »
ok its running, and ive turned off the start recording log thingy.
still the same
« Last Edit: August 22, 2009, 03:20:16 PM by DoctorM »
« Reply #22 on: August 22, 2009, 03:56:44 PM »
still the same
What's still the same?  Do you mean you're still not seeing callsigns, or still not seeing registrations?
If you're not seeing Callsigns, then I'm out of ideas.
If you're not seeing Registrations, have you setup a populated basestation.sqb file, and selected that file in Planeplotter (Options - Directories - SBS1)?
