Author Topic: V3.02 Beta Ready to be Tested  (Read 6275 times)
EI4GXB
  • RadarBox Beta Testers
Re: V3.02 Beta Ready to be Tested
« Reply #15 on: August 25, 2009, 09:34:56 AM »
V3.02 working perfectly no issues here. Located 8km SE EINN.
Well done Airnav, you have a winner!
Frank
« Reply #16 on: August 25, 2009, 09:54:44 AM »
On the 22 of July you wrote:
>-Flights on the network grid still jump around but not as bad as in the last exe...or so it seems so far.
We are still working on this one.
This problem still exists.
Frank
EMA
« Reply #17 on: August 25, 2009, 03:00:43 PM »
The only thing I have noticed is that on one of my PC's which is set to go in to sleep mode after 60 mins, on resume I get ANRB.exe stopped working and the program closes. Prior to this it use to just pick up when my PC woke up.
I do not see this as a big issue and all alerts set have reported fine, no problems with network etc.
The only item I cannot test is the ports because I do not use those features.
I have tried hard to break it without success ;-)
Kevin
« Reply #18 on: August 25, 2009, 04:01:22 PM »
I've tested both standby and hibernate, and this latest beta survived both events (as did previous v3 versions).
abrad41
« Reply #19 on: August 25, 2009, 05:12:39 PM »
AirNav
Everything is working how it should be this end, Thank you again for your hard work.
Andy
EMA
« Reply #20 on: August 25, 2009, 05:17:37 PM »
Previous versions worked for me as well but for some reason 3.02 ANRB.exe does not survive standby from my Dell XPS it happens everytime although as I said previously I am not bothered just reporting back.
« Reply #21 on: August 25, 2009, 09:57:24 PM »
All seems to be working well with V3.02.  Stable with no obvious bugs that I've found.
pjm
« Reply #22 on: August 26, 2009, 06:31:30 AM »
Same here - all seems very stable - no bugs with the existing code that I've seen.
« Reply #23 on: August 26, 2009, 12:21:44 PM »
Worth saying that I'm seeing more alerts now as well.
So, is this version ready for public beta?
« Reply #24 on: August 26, 2009, 01:27:19 PM »
Looks like it :), we just need  a few more thumbs up from other beta users.
« Reply #25 on: August 26, 2009, 02:12:57 PM »
We have identified 3 problems with the current version (minor ones) and one of our programmers is working on them for the next 2 days. After that all seems to be Ok for public beta.
prbflight
« Reply #26 on: August 26, 2009, 03:01:08 PM »
The latest beta has been 100% stable.  Great job AirNav.
Paul@cyyb
« Reply #27 on: August 26, 2009, 03:17:47 PM »
Don't break anything!
EMA
« Reply #28 on: August 26, 2009, 05:45:44 PM »
Two full days of testing with no major issues.
We had better get our tins hats ready for the public release :-)
CAM
    • http://www.planedaft.co.uk
« Reply #29 on: August 27, 2009, 11:52:58 AM »
Also had two days of running with no issues.
Tin Hat Time !
