Am I the only one with slow menus & crawling PC here?
Started by GlynH, August 27, 2009, 10:34:39 AM
GlynH
Quote from: EMA on August 31, 2009, 08:25:57 AM
When I did testing with Aleksey we found switching the map off stopped the slow menu issue so I am interested to know if the same happens for you.
Hi Kevin,
I tried this the other day and posted the result here;
http://www.screencast.com/t/XatRkoG9BGm
Better as in no menu tearing/visible redrawing but still slow to respond and then the damn sleepy pointer rears its ugly head again...
Thanks all for your suggestions & continued patience.
Kind regards,
-=Glyn=-
#46
Quote from: GlynH on September 02, 2009, 06:14:47 AMAny suggestions as to the best way to investigate I/O would be much appreciated.
Perhaps someone with XP can suggest the best way.  In Vista (yes, I know you hate Vista, I find it works great), I use the Reliability & Performance tab in Computer Management.  Here's a typical disk-churning episode, where the MyLog journal is having a series of large re-writes.  Whilst this is happening, my PC becomes slow to respond as well.
A good place to start is right-click the drive that RB is installed on, and select Properties.  Check whether the drive is compressed or indexed - indexing can be a real I/O hog.
