Airnav & Vista
Started by Bigyun2000, September 03, 2009, 12:32:51 PM
Bigyun2000
@tarbat
I don't know how you do it.  Ever since i bought my 1st ANRB i have always had the same problem.  3 Laptops later and about 4 ANRB boxes later i still have the same problem.
I always have MS Office 2007, Adobe reader, ADU, WXTrack, Flash FXP, Roxio Creator, Adobe Photoshop, some scanner programming software, Shipplotter, SnagiT, PCTools Desktop Maestro and Kaspersky Internet Security.
The Kaspersky is a new one for me as i usually use AVG.
So i must be the only one still having this age old ERROR.
Quote from: Bigyun2000 on October 10, 2009, 04:40:12 PM@tarbat
I wish I knew as well!!  I run a lot of beta software on my PC, and Radarbox has been one of the least problematic.
Bigyun2000
@ tarbat.
I run many programs too.  I am a Radio Ham and enjoy decoding stuff but all that has been uninstalled.  I have stax of scanner programming software running.  Even tried uninstalling them.
I keep everything fully up to date via Windows and Microsoft Update.
Anyway I just guess i will have to put up with it.
Problem is that i keep putting up with it then decide to sell it and buy the SBS-1e
As i have no problems at all with that.
Tony
Bigyun2000
@ AirNav Development.
Hi.  Can you tell me where i would possibly find a report either in AirNav or in Vista where it may give me a clue as to the error i am still having please.
"ANRB NOT RESPONDING" error
Downloading the 3.07 full version should rectify that issue.
Bigyun2000
@ AirNav Support.
I am downloading this very moment.
THANKS
#21
Quote from: Bigyun2000 on October 11, 2009, 05:35:30 PMHi.  Can you tell me where i would possibly find a report either in AirNav or in Vista where it may give me a clue as to the error i am still having please.
Computer Management - Event Viewer - Windows Logs - Applications
Then look in Control Panel - Problem Reports and Solutions
Bigyun2000
Thanks tarbat.
Done it now.
THANKS
Bigyun2000
@ AirNav Support.
Hi again.  Uninstalled ANRB v3.06 - Downloaded full version of 3.07 and re-installed.
Working for 10 minutes then run Internet explorer v8 and guess what. Yes
"ANRB NOT RESPONDING" error.
Please see the picture.  Shows the problem, maybe you can understand it.
Thanks.
Can you run internet explorer (no addons) - this will be in your start menu under acceserioes and then system tools, with 3.07 and see whether that works.
A failure in ntdll.dll suggests a problem when calling a windows kernel function.
Bigyun2000
@ AirNav Support.
OK I closed Explorer.  Re-opened it then run 3.07.  So far so good.
Going to close IE8 and try opening IE8 again.  If still OK I will open OUTLOOK 2007 as that seems another point when ANRB errors out.
Tony
Bigyun2000
@ AirNav Support
1. had 3.07 running with IE8 so closed IE8
2. 3.07 still running no problems
3. opened IE8 - 3.07  ANRB NOT RESPONDING
Are you running it with the no addons. We would assume 50% of customers would be using i.e 8 at the same time as RadarBox so we think it could be one off those addons which is causing something.
Bigyun2000
@ AirNav Support.
I am not sure about addons.  Can you give examples please as far as I know I have none.
Tony
