RELEASED - AirNav RadarBox 2009 - 3.06 Beta
Started by AirNav Development, October 01, 2009, 01:03:41 AM
Where are you installing to?  If you're running Vista, do NOT accept the default location folder - C:\Program Files\etc.....
Instead use a folder something like C:\Airnav\
That may not be the cause of your problem, but it's worth a go.
viking9
Hi Michael,
I had that problem. I cured it by downloading the ANRB.EXE file (manual installation) and replacing the current ANRB.EXE file with it.
Tom
Tom
Bury St Edmunds, Suffolk UK
15 miles SE of EGUN
http://www.viking9.co.uk
Quote from: viking9 on October 07, 2009, 09:13:19 AMI had that problem. I cured it by downloading the ANRB.EXE file (manual installation) and replacing the current ANRB.EXE file with it.
Worth a try.  Here's the link:
http://www.airnavsystems.com/download/anrb/beta/anrb.exe
Download and put in your Radarbox folder, replacing the existing anrb.exe
vassylad
Thank you but do I neeed V3.01 already installed to run V3.06 or can I just d/load V3.06 into another folder of my choice without having V3.01, If I do need 3.01 is there a link for it please, windows vista is a pain in the rear
Michael
Uninstall.  Download the latest v3.06.  Install into C:\Airnav
You don't need any earlier versions.
vassylad
Hi Tarbat I opened the link for manual install and got the following message.
This application has failed to star because rb.dll was not found. Re-installing the application may fix this problem.
Michael
[/quote]
Quote from: tarbat on October 07, 2009, 09:45:44 AM
Quote from: vassylad on October 07, 2009, 09:58:14 AMHi Tarbat I opened the link for manual install and got the following message.
Save it, don't open it.  Save it in the Radarbox folder on your PC.
p3orion
Tarbat
thanks for the information thats done the trick on XP will give it a go on Vista when I get home from work
thanks for the advice
regards
Colin
After doing full install of 3.06 beta, first time I ran it,  I got an Access Violation.
Unfortunately I did not think to screen shot it, and so I missed the instruction address.  My only option was to hit okay, and then it kept cascading with that message. there was no option to terminate it, and it just kept looping with more of these.
Second time I ran it, I got an Access Violation at address 007D559A in module 'ANRB.EXE'. Read of address 00000374.
Colin
I forgot to mention it also pops up a message after hitting okay saying it needs more information on the station.  It is very hard to kill, because about once a second the access violation starts coming up.
Fenris
Quote from: Colin on October 07, 2009, 02:48:05 PM
It sounds like for some reason the registry keys have not been written correctly, all the settings are stored in the registry.
Are you able to run regedit to have a look?
simone.simone
#131
Onother one...
I've tried to clear the registry about any RB entry, but still having problem.
EDIT: SO XP SP2
vassylad
Hi I have had that same message numerous times and yes the pop up cascades until you hit ctrl alt del and cancel it thru the task manager, why cant this be as easy to install as previous versions?
Is it a Vista issue, I was quite relieved in a way to see that it is not only me getting the pop up!!
So what do we do guys..
Michael
Quote from: simone.simone on October 07, 2009, 08:44:14 PM
Onother one...
cornish rebel
Hi all I also had the same problem today when I did full install of 3.06 beta as said before in a earlier post it keeps popping up with no way of stopping it the only way i found was restarting my computer I uninstalled it after that I installed it in to a separate folder than the default location will try again when I get a chance but not really bothered as this is only a beta version I would rather wait till the full version comes out when ether that will be
I'm running windows vista  basic 32bit
Located in Limerick Ireland about 20 odd miles from Shannon airport EINN
Hi all,   I've been trying to get the full version of Beta 3.06 to download and install - about 6 times, so far.      The program seems to download OK (20 - 30 minutes later!), but on trying to run or install, it seems to go through all the correct steps, but as soon as the screen comes up with ANRB serial number and supplied password, hit the start button and I get one error message
Headed "ANRB 2009 - 3.06 Beta"
Script "Access Violation at the address 007D559A in module 'ANRB.exe'.   Read of address 00000374"
then 51 error messages
Script "Access Violation at the address 007DA682 in module 'ANRB.exe'.   Read of address 00000378"
I can be quite specific about 51, as I then get a Microsoft Windows message saying ANRB.exe has stopped working (didn't I guess???), Windows will try to find a solution, which it doesn't.
The OS is Vista Home Premium, and I've previously had the 2009(8) CD version, and all 3 Betas running without any problems.
I have recently had to reset the laptop and restore (re-format HDD to original partitions) to original Acer factory defaults, all AirNav files and references have been deleted.    This reset was undertaken, as a change of ISP from Orange to BT Internet, resulted in continual freeze-ups (appearances of BTFON and Openzone unsecured internet screens, which would not allow internet access).
Any suggestions please, before this flaming laptop gets launched off the nearby cliff.
I originally posted this as a new topic, but obviously it should be in here (Sorry, AN!).
