AirNav RadarBox 2009 - 3.07 Beta
Started by AirNav Development, October 11, 2009, 02:28:41 AM
Canonjohns40D
Hi Tarbat, Freqhopping and Bratters and thanks for taking the time to assist.
Right checked in the database and 163310 looked no different than the other entries around it. It does now as i deleted it. I then deleted the old data as you suggested Tarbat.
Sorry bratters I saw your post and being  a bit of a numpty with computers bottled it. I'll try the other two options for now and monitor the situation.
If it returns later tonight or tomorrow I'll try your suggestion.
Thanks for your time it really was getting very frustrating.
John
John Racars
Hi Support & All,
A new phenomenon? For me it is. I saw this on my screen this afternoon:
1. BAW63 EGLL-HUEN appears on my screen as networkflight (*) a/c in service: G-BNWZ
2. five minutes later this aircraft arrived in my area of reception (* disappeared): flightid changed into BAW874 EGLL-HUEN
What is happening here? Allready reported to you? If so: sorry for this.
BTW: BAW874 should be EGLL-UUDD but that aside.....
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
Its not new, we mentioned before that if the Flight ID changed it doesn't recheck the route and this would be looked at.
John Racars
#168
Thank you! But what is not new?
13 NM East of EHAM
ANRB:
You said new flight id problem. Its not new it has been known before.
John Racars
Oh, you are so kind!
The route problem is well known but what do you have to say about what I said in the first place?
For your information again: change of flight id between network>own reception. Do I made my self clear now?
13 NM East of EHAM
ANRB:
Aerotower
#171
Another error.
Cumps
Quote from: John Racars on October 31, 2009, 12:03:24 AMFor your information again: change of flight id between network>own reception. Do I made my self clear now?
That does seem to be a different issue.
According to my log, over 2 hours elapsed between G-BNWZ arriving at Heathrow yesterday as the "BAW63" LGAV-EGLL (1102z) and departing as the BAW874 EGLL-UUDD (1320z).  I would have thought that the inbound flight would have timed out on the network well before then.
Incidentally the inbound aircraft was sending the wrong Flight ID - it was actually operating the BAW631 (though I don't think that's connected to the problem being discussed).
Canonjohns40D
Hi Tarbat, Freqhopping, bratters and perhaps Airnav Support in particular.
Quote from: Canonjohns40D on October 30, 2009, 09:23:55 PM
John
Well a quick look this morning and despite the above he is back??????????????
401174  GEURT                    163310  ...   USA - Marines        2009/10/31 08:40:07
   405D0D  EZY33KH  EGPH-EGGW       163310  ...   USA - Marines        2009/10/31 06:57:49
   405D0D  EZY33KH  EGPH-EGGW       163310  ...   USA - Marines        2009/10/31 09:23:50
   405D0D  EZY5UB   EGPH-EGGW       163310  ...   USA - Marines        2009/10/31 09:04:46
   4060A4  BEE601   EGNS-EGGP       163310  ...   USA - Marines        2009/10/31 07:22:04
   4060A4  BEE602   EGGP-EGNS       163310  ...   USA - Marines        2009/10/31 08:46:53
   AE20C3  RCH604                   163310  ...   USA - Marines        2009/10/31 08:19:56
What now?
John
John,
If you use Database Explorer and search for the following Mode S codes, what do you see?
401174
405D0D
4060A4
AE20C3
Make sure you have the 'aircraft' table selected and use:
Text to find: 401174 Condition: IN Field: MS
Do all these aircraft show as being 163310 USA - MARINES
I've checked my database using Database Explorer and all the info looks correct.
Canonjohns40D
Hi Allocator
Hmmm!!!!!!!!!!
I just tried this twice. Table selected is Aircraft typed ModeS code in, condition field set as In drop down list for field only offers AT AN AG and It wont let me insert MS manually?
Corrupt database?
John
#176
You have to select 'aircraft' at the top in the Select Table drop-down.
You have 'actype' selected at the moment.
If you cant see:
MS
AR
AT
AN
etc in the drop-down, then you do have a corrupted database.
Canonjohns40D
#177
Hi Allocator
No selected Aircraft and only AT AN AG are availble Select any other field and the options chance A/C typ as you would expect AT AN AG. Airports gives P4 P3 PN etc and Airlines gives CN C£ etc.
Aircraft selected and it will not change.
Help please!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
John
Canonjohns40D
Right our posts crossed so a corrupt database it is then? How can I reload the database please?
John
besty
Hi John just had the same trouble my database died too, strange, but I loaded version 2 and used the basic database then deleted the one in v3.07 and wrote in the one from v2. Not sure if it's the best way but it worked now able to alter and select aircraft but going to have to play catch up with '...' aircraft.
If you have a backup try using that, mine all seemed to go the same though.
Stuart
