Radarbox is "blind" for the planes above my head
Started by vic_atc, November 07, 2009, 05:44:15 PM
Mike_Tassy
I have a capture from today, how should I send it? Can I attach as a file to a post
Mike
Quote from: Mike_Tassy on November 19, 2009, 07:06:30 AM
I don't see why not - people attach fairly massive images to some of their posts, so size shouldn't be a problem (but Zip it first!).
Mike_Tassy
Hi The aircraft in question is TGW572  -  VH-VNF  -  7C6C29
It passed through my no go zone at time 17.37.35
Attached is a txt file
Mike
Quote from: Mike_Tassy on November 18, 2009, 10:31:22 PMHi I am able to connect to 30003 and see data stream with telnet,  how do I capture to a file.
Probably easiest thing is to use SBSSIM.  This will let you capture port 30003 output to a file.
[attachment deleted by admin]
Quote from: Mike_Tassy on November 19, 2009, 08:09:21 AM
OK - I have good news and bad news.
First the good news, you aren't losing the signals from aircraft above you - they are still being received, so there's nothing wrong with your RadarBox hardware or aerial.
Now the bad news, there is a position encoding/decoding bug which means that aircraft latitudes and longitudes aren't being shown correctly.  My money is on a decoding bug in RB, simply because if it were an encoding bug on board the aircraft I think we'd have heard about it before now (it affects several aircraft in your sample, not just VH-VNF, and not all the time either).
What is happening is that, at a certain point in their trajectory, RadarBox starts outputting longitudes with a minus 360 degree offset so that, for example 146 degrees E (+146) becomes minus 214 degrees W (-214).  Obviously that means the resulting position can't be plotted on the map, so the aircraft symbol disappears from your screen.
I have no doubt that AirNav Development and Support are monitoring this thread too, so we'll leave it in their capable hands.
OKC-Steve
#82
Looking at the Socket Output, it is not compatible with the SBS-1 either.  The last four numbers should be 0,0,0,0 as default (for false) and -1 if any of them are true.
The decoding code should probably issue an exception if lat or lon are unmappable.
Might this be connected to the blind rectangle near New Zealand?  I suggested a possible decoding error for that problem, but I don't think it got pursued any further.
http://www.airnavsystems.com/forum/index.php?topic=3452.msg33227#msg33227
OKC-Steve
Quote from: tarbat on November 19, 2009, 10:22:21 AM
I think you're right.  Looks like his trouble ticket got abandoned.
Fenris
Well, it's good news that it has been identified and it's a software problem. They are easier to fix than hardware problems, especially ones common to all shipped hardware.
Nothing has been confirmed yet. Let us fully investigate all the details.
We did conduct similar tests as Dave has done on an customer in India who mentioned similar results earlier this year however we didn't find a software or hardware issue.
Mike_Tassy
Quote from: OKC-Steve on November 19, 2009, 10:11:55 AM
By this do you mean the SBS will have the same problem??
I have the SBS1-e and it doesnt suffer from this
Mike
Ahem !  As did I, two posts prior to yours !  :-)
Mike_Tassy
 "(it affects several aircraft in your sample, not just VH-VNF, and not all the time either)."
I notice the ANRB does lose some position plots in other areas as well, they just seem to drop in and out, where the SBS does not.  Hope it can be fixed and thanks for the help as I really like the ANRB software, and I will only keep one box, sell the other off
Mike
