AirNav RadarBox 2010 - 3.11 Beta - Released
Started by AirNav Development, November 23, 2009, 01:44:33 AM
Brimon
Quote from: lambertw on November 24, 2009, 06:45:52 PM
I get the same message when I come out of the forum page,then anrb shuts down.
If I am on the internet & come off it,Radarbox crashes. Strange.
Chasing the heavies from a secret bunker in Scotland
vonsmalhausen
Quote from: Fenris on November 24, 2009, 06:21:14 PM
I'm still experiencing a warning message from 3.11 beta when it is closed. I thought that it shut down OK on the first occasion, but today it threw up the Vista warning dialog saying "anrb.exe has stopped working" and offering to try and search for an explanation.
Is it only me that has this problem? Not seen any other reports.
not only you, i have the same problem since 3.08 , never had it before, hoped it would be gone with 3.11, but no.
Netcop: we have Pmed you. pls answer our message.
Users having the shutdown message, pls send a screen shot of the message so we can analyze it in detail.
CoastGuardJon
Quote from: tarbat on November 23, 2009, 11:05:05 PM
Jon, it sounds like Windows is still using the anrb.exe.  Try re-booting the PC, then DON'T run Radarbox, and try replacing anrb.exe with the new one.
Hi Tarbat and all who've offered help - SUCCESS AT LAST!!    With RB disconnected from lap-top, Shut Down completely, re-started computer, went into C drive, clicking until I found the screen listing all the files "color, data, drivers" etc..    I then renamed the ANRB file as "old 3.07", I could then Cut and Paste the 3.11 file to replace it, plugged RB in and immediately (more quickly as well) started to open and run OK.     Many thanks to all for the patient assistance.
I'm now getting network flights fine, but virtually nothing from hardware.     I've got a Returns Ticket No., but have delayed posting to W&S until I received a brand new antenna from them (ordered Sunday, received today - spot on!), to prove it's not antenna related.     The wind and weather are such at the moment, I wouldn't really want to put an exterior antenna out in it, let alone a brand new standard one.     The box seemed to die Sunday before last, fine in the morning averaging 30 or so in My Flights, then zilch in the afternoon.    Mine is one of the new Serial Nos (<12months old, with 2009 sticker on the box sleeve).
vonsmalhausen
Pls check your personal messages and send the screen shots to the email address supplied there. We have also more details on the personal message we sent you.
charlie
Just loaded up 3.11.
Larger number of contacts than usual for this time of night usually 40-45 now 60-70
lambertw
bailey_uk
Hi folks, not logged in for about a month now and lots seems to be happening!
Im currently on anrb 2.0 and would like to run the newest beta.
I notice that the latest beta is only a partial download update thing, so seached back to 3.07 however the link in that thread for the full .exe seems to be dead.
Any chance there could be a full .exe download of the latest beta version?
Thanks!
airdata
3.11 Beta is working very well here and I am very happy ythat the blind rectangle is finally gone.  The only issue I have is  that the current map is not saved on exit.  On starting ARNB a different map appears
Under the flight path, 5NM from runway 23L threshold at Auckland (NZAA), New Zealand.
Airdata - we can appreciate your greater coverage on the network - with that and the "Tasmanian black hole" fixed, we're seeing a lot more flights!
About the map - have you chosen Window...Record Desktop while you have the correct map set? That might help.
Fenris
Quote from: lambertw on November 24, 2009, 10:12:29 PM
Screen shot of shutdown message.
That's the same thing I'm seeing, although I had not expanded the details.
Airnav: there is no anrb.elf file to send you, however what I did notice on starting RB this morning is that the vastly expanded polar diagram from yesterday is not saved so maybe the crash has something to do with that.
I'm going to reset it and see what happens.
Roadrunner
I get a similar box come up. Is there a common thread ie, my system is Vista 32-bit.
Mike
Quote from: Roadrunner on November 25, 2009, 10:14:18 AMIs there a common thread ie, my system is Vista 32-bit
I'm running Vista 32-bit, and I don't get the shutdown error.  Must be some other common factor.
Fenris
Well I am also running Vista Home Premium 32-bit with SP2, so it may be a Vista thing. But the Tarbat always has seemed to have a blessed installation ;-)
