Database update info
Started by DaveReid, February 03, 2010, 09:36:50 AM
Marpleman
ACW367
Quote from: DaveReid on June 11, 2010, 06:42:18 AM
Quote from: DaveG on June 08, 2010, 06:28:25 PMReply 153 & 154 have been updated in DB
Something not quite right here - the newly-created record for that Falcon 2000 has the correct type and msn, but a photo link and thumbnail of a Lancair that was de-registered in 2003 ...
Quote from: ACW367 on June 04, 2010, 04:48:16 PM
Airnav are aware that there is an issue, in that data that we are entering for the AT PT and LK fields is not filtering to users. This means that in a very small number of cases you will still get a incorrect photo or non standard ICAO code. Airnav have this as a priority fix and it should be resolved shortly.
Dave See my Quote above.  Airnav are aware of the bug and we hope to have this resolved shortly.
Quote from: ACW367 on June 11, 2010, 11:37:53 AM
OK, thanks for that - I hadn't realised that the spurious photo links bug applied to newly-created records as well as to existing ones.
On MyFlights ths morning:
Mode S: AC86A4
Reg: N906NB
Type: Falcon 7X
ICAO: FA7X
MSN: 74
Currently populates as Reg: (blank);  Type: (blank);  ICAO: (blank);  MSN: (blank)
This information is hereby placed in the public domain and may be freely used without attribution by any individual or organisation.
MTIA
Dave
DaveG
Cornwall, UK
John Racars
Any change of this flight?
BAW20U = ?-?
Thank you in advance!
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
DaveG
the aircraft used could have been:
G-EUUZ, A320-232, 405A48
It is in the database correctly.
Cornwall, UK
ACW367
Dave R it would really help us if you include both owner (from the Register) and Operator (from the RVSM Monitoring Orgs or other sources) with the data block you include in your post.
ACW
Quote from: ACW367 on June 11, 2010, 06:39:19 PMDave R it would really help us if you include both owner (from the Register) and Operator (from the RVSM Monitoring Orgs or other sources) with the data block you include in your post.
OK, I'll see what I can do, although it's an automated routine that I'm running to cross-check local and network flights against my master database, and I don't have time at the moment to tinker with the code.
On MyFlights yesterday evening:
Mode S: A4D9A3
Reg: N411UK
Type: Cirrus SR-22
ICAO: SR22
MSN: 3696
MTIA
Dave
N411UK added to databade, thanks Dave
On MyFlights yesterday:
Mode S: A68A81
Reg: N520SC
Type: Canadair CL-600 Challenger 605
ICAO: CL60
MSN: 5779
MTIA
Dave
Wouldnt have got that one from the usual sources. LJ60 on Airframes and nothing on GAS.  Details on FAA though
Added to database
Quote from: Runway 31 on June 16, 2010, 02:03:50 PMWouldnt have got that one from the usual sources. LJ60 on Airframes and nothing on GAS.  Details on FAA though
Well I guess I should be glad I'm not classed as a "usual source"  :-)
