Are you a Leftee or a Rightee?
Started by Bell 407, February 27, 2010, 06:55:34 AM
eggplant
On Mondays, Wednesdays, Fridays and Sundays I have the list on the left, map on the right. Tuesdays, Thursdays and Saturdays I have the list on the right, and map on the left.
Oddly enough I am ambidextrous - possibly coincidence ?
Frank
Bell 407
I suppose things will all change again once AN gets the map undock issue done. Then it will be are you a Dual Screen Leftee Mapper or a Dual Screen Rightee Mapper?
colinhall
map on the left and list on the right,only way to have it!!  he he.    Colin
radarspotter10
Quote from: Jeremy on February 27, 2010, 11:55:10 AM
For once I have to agree with Pat!!
How about a break away group?
J.
Quote from: radarspotter10 on February 27, 2010, 11:19:37 AM
List on the left and map on the right and I am right-handed
from pat
ps:
I wonder if your eyes are the same?.
from pat
hi hi old man.
Map left, list right - right handed.
charlie
naird
RB  List on left   Right Handed
SBS  map on left  list on right ;-)
boss
dl1812
I'm cross-eyed and ambidextrous - I've no idea where mine is  :o)
Pinza
List left, 3D window right - both on RH 22" monitor.
Planeplotter running 2D map on (left hand) laptop screen.
Works for me - but may try using ANRB split view option - swapping list to the right and having both 2D and 3D maps to the left - then dragging 2D view onto LH laptop.
Will give this idea a try later
mjleprix
Map on the left-list on the right and I'm right handed. Could never get used to it the other way round for some reason which escapes me. But it'so long since i've seen clear skies, I had to look to confirm that.
Mike P
Rural Outpost
Currently list right map left. I do change it around though quite regularly when bored, just like today because of the cloud cover.
RO
Jeremy
If you are right eye dominent then you always look at the rightside of something first i.e. a newspaper. If the map is of more interest to you than the table then the map should be positioned on the right.
J.
G4DOQ
QRZ.com
TGA388
Quote from: eggplant on February 27, 2010, 12:54:12 PM
I am a Rightee and I am Right-handed, but I would give my right arm to be ambidextrous :-)
Dave
