Author Topic: Database Spring Clean  (Read 29832 times)
dudbaker
Re: Database Spring Clean
« Reply #15 on: March 21, 2010, 10:56:48 AM »
Thanks but I am not worried about My flights or Network.  My concern is:  I update Mylog which resummable updates mylog.db3 then next time the aircaft is detected it deletes my amendment.  Eg, there is ... in a box.  I replace this A64D.  Next time the aircraft is detected ... .  Or even worse if empty then amended becomes empty next time the aircraft is detected.
Dudley
Dudley Baker
Stansted
G8THH
« Reply #16 on: March 21, 2010, 11:05:18 AM »
So why don't you make the change in NavData.db3 using Database Explorer then?  That is where the ... is coming from.
If you then manually delete the ... in the MyLog entry, a MyLog Populate will then write in the correct data that you have entered using Database Explorer.
abrad41
« Reply #17 on: March 21, 2010, 11:15:47 AM »
Quote
Try these instructions - http://www.tarbat.gofreeserve.com/instructions.htm
May I add to this - tarbat instructions will not work with the latest version of SQlite, What I do is export with the latest version and import with the previous version.
Quote
The MyLog database is populated from the data that is in NavData when the aircraft is detected and in written to MyLog.
Can I remember something about all the fields must be populated in the NavData, including the PT,LK,PT2,LK2 fields for the information not to be over written.
Andy
dudbaker
« Reply #18 on: March 21, 2010, 12:02:03 PM »
I put Database Explorer in Google and came up with pages of them.  Can I use any of them?
Dudley
Dudley Baker
Stansted
G8THH
btclarke
« Reply #19 on: March 21, 2010, 12:25:51 PM »
How about AirNavSupport give a little tutorial for us?
    • Rod's RadarBox Downloads
« Reply #20 on: March 21, 2010, 05:00:14 PM »
Dudley
We're talking about the Database Explorer that you get when you use RadarBox's File menu and choose Database Explorer there. That's the manual way to get to the NavDatat.db3 file.
dudbaker
« Reply #21 on: March 21, 2010, 05:07:04 PM »
Tried that with the same result.
Dudley
Dudley Baker
Stansted
G8THH
« Reply #22 on: March 21, 2010, 05:27:54 PM »
Dudley
Have you watched the AirNav video on Manual Database updates?  via the button at the top right of the Forum.
You can also right click on the aircraft in the list and go straight to that aircraft in the database.
btclarke
« Reply #23 on: March 21, 2010, 05:59:44 PM »
Thanks for that! Is there any way to update the stored records?
« Reply #24 on: March 21, 2010, 06:04:57 PM »
If you mean the MyLog records, yes.
Using the MyLog window and the edit/delete buttons to change the fields.
Or, as I mentioned previously - If you then manually delete a field in the MyLog entry, a MyLog Populate will then write in the correct data that you have entered using Database Explorer.  Try it with one record to see how it works.
dudbaker
« Reply #25 on: March 22, 2010, 10:01:56 AM »
The video, highlighted by Allocator, makes play of selecting Show All before coming out of Database explorer.  I have tried that.  I need to detect some aircaft to prove the results.
Dudley
Dudley Baker
Stansted
G8THH
dudbaker
« Reply #26 on: March 22, 2010, 11:50:59 AM »
Detected ZH888 twice today.  Both occasions C130J became C130 in Mylog.  Database Explorer remained C130J.
Dudley
Dudley Baker
Stansted
G8THH
« Reply #27 on: March 22, 2010, 11:59:33 AM »
If it's of any interest to anyone, here's the utility I use on those occasions where I need to make manual updates to the NavData.db3 database:
If there's sufficient interest from users who want to manually update their NavData, now that AirNav seem to have decided to do nothing about the database from their end, I'll look at making the utility available for download.
« Reply #28 on: March 22, 2010, 12:29:29 PM »
DaveReid,
Just because we haven't bought your services doesn't mean we have decided to do nothing. We have stated clearly more than once that we are looking into this and will have news soon.
« Reply #29 on: March 22, 2010, 01:21:00 PM »
Fine, I stand corrected.
In the meantime, I'll do my best to assist users who are endeavouring to keep their NavData.db3 up-to-date themselves from external sources.  Presumably you don't have any problem with that.
