Author Topic: Software problems radarbox 3.13  (Read 26517 times)
Aerotower
Re: Software problems radarbox 3.13
« Reply #30 on: June 14, 2010, 11:52:51 PM »
continuation
« Reply #31 on: June 15, 2010, 06:27:44 AM »
Guys have a serious problem when closing the software radarbox (closes completely) when switch back on all my flights for the day of mylog disappeared from the list. And do not know why he was working so well ....
I need help also from AirNav
Look at the examples of this plane BAW (which I lose :( )
and see the time in software
This looks very similar to the bug you reported back in December:
www.airnavsystems.com/forum/index.php?topic=3963.msg40003#msg40003
If so, it's currently in the bug list as "Not seen in 3.13 full release, only beta, considering closing" - see www.airnavsystems.com/bugs/index.php?do=details&task_id=11
Aerotower
« Reply #32 on: June 15, 2010, 10:17:09 AM »
The problem was the file Mylog.db3.bak not know what happened internally at RB for this to have happened. Now I copied the file Mylog.db3 and changed the name to Mylog.db3.bak and you're OK, but still made me lose flights yesterday and today.
Best Regards
P.S.-But I came back to turn off and on the software and returned to lose the data, ie the Mylog.db3.bak is not updated with new data and when it reconnects the software, it erases the data and replaces Mylog.db3 by Mylog.db3.bak data.
« Last Edit: June 15, 2010, 11:52:39 AM by Aerotower »
Aerotower
« Reply #33 on: June 17, 2010, 06:23:44 PM »
What do I overcome this problem?
Can anyone see what is happening with my Mylog.db3 and eliminate the errors contained therein?
« Last Edit: June 17, 2010, 07:05:29 PM by Aerotower »
« Reply #34 on: June 17, 2010, 07:14:12 PM »
Looks like your database is corrupted.  Two suggestions:
1. Delete the database, and next time Radarbox starts it should create a new, empty database.
2. Try opening the database in something like SQLite Maestro, and see if you can run maintenance on the database to correct the corruption.
Any ideas what may have caused the corruption?
Aerotower
« Reply #35 on: June 17, 2010, 07:27:40 PM »
No idea Tarbat.
I have no program to open the database, if you want help I will send you the database by email.
Delete 6000 flights was not very good idea.
[attachment deleted by admin]
« Last Edit: June 17, 2010, 07:42:42 PM by Aerotower »
« Reply #36 on: June 17, 2010, 07:43:52 PM »
No, I don't want help - I thought it was you that wanted help.  I was just trying to help.
Aerotower
« Reply #37 on: June 17, 2010, 07:50:19 PM »
I need help.
Can you help me?
Sorry my English
Best Regards
« Reply #38 on: June 17, 2010, 07:55:08 PM »
I need help.
Can you help me?
Okay, the only things I can think of is to either delete the database, or use something like SQLite Maestro to see if it can be repaired through the Maintenace menu.  When do you see the "corrupted" message?
I've never heard of this happening before, so wondered if you'd done anything "unusual" to the database to cause the corruption.
Unless anyone else has a better idea?
Aerotower
« Reply #39 on: June 17, 2010, 07:57:48 PM »
So I start Radarbox.
I do not have this program and know how to work with him :(
Aerotower
« Reply #40 on: June 17, 2010, 07:58:35 PM »
Best Regards
Now installed the version 4.03 and copied the Mylog.db3 to the directory.
Only!
« Last Edit: June 17, 2010, 08:00:28 PM by Aerotower »
« Reply #41 on: June 17, 2010, 08:04:48 PM »
Okay, I've looked back over some of your posts.  I understand you're running Win7 and AVG.
So, have you setup exceptions in AVG for the Radarbox folder and the Virtual Store Radarbox folder as well?
Aerotower
« Reply #42 on: June 17, 2010, 08:09:07 PM »
I have exceptions in AVG. And the directory radarbox is directly in C:\
« Reply #43 on: June 17, 2010, 08:38:34 PM »
I'm out of ideas, other than deleting the MyLog database or trying to repair it in SQLite Maestro.  Sorry.
Aerotower
« Reply #44 on: June 17, 2010, 08:42:41 PM »
You can repair my mylog? I send you by e-mail.
