Started by Marpleman, May 26, 2010, 09:23:34 PM
Chris11
#1095
800435 VT-WAF A320-214 3306 GoAir
80051B VT-INZ A320-232 3943 Indigo
800596 VT-IGL A320-232 4312 Indigo
orkney
Hello
All 3 Airbuses  Added now -thank you.
Andrew
Horsham Spotter
Good evening Andrew.
Please find enclosed a few found today.
ACAC32/N9154R/M20P/Mooney M20J/Larsen Paul D/24-3247
400BC1/G-RVRX/P68/Partenavia P68B/Ravenair Aircraft Ltd/62
43C4C6/ZA679/CH4/Chinook CH-47D/Royal Air Force/M7014
4843B0/PH-PPS/C208/Cessna 208B/Blue Skies Aviation B.V/208B0773
A79B1C/N59AP/GLF4/Gulfstream Aerospace G-IV/Computer Science Corp/1476
3E189A/D-IANA/BE20/Beech B200 Super King Air/Dix Aviation/BB-1517
4041E1/G-IRKB/P28R/Piper PA-28R-201/Raymond Keith Brierley/28R-7737071
Hope of uses Steve.
3.1nm miles south of EGKK westerly App & Dep.
orkney
Hello
All Added Thank you.
Andrew
andrewarles
A/c not populating
405426 / G-LULV / DA 42 / 42.313 / DELTABOND LTD
A82E5B / N626UT / G-V / 648 / WILMINGTON TRUST CO TRUSTEE
A9A7B3 / N721EM / MOONEY M-20TN / 31-0064 / N721EM CORP TRUSTEE (Callsign N721EM)
3810DA / F-WWDH  Airbus A.320 Test registration
Andrew
16 NM SSW of LFMV (Avignon)
27 NM NW of LFML (Marseille)
Arles, France.
orkney
Hello
All added once more thank you.
Andrew
knight01
no info: 42498B - using callsign AFL8252
ACW367
#1102
Quote from: Horsham Spotter on October 20, 2010, 06:07:39 PM
Hope of uses Steve.
Steve
The correct ICAO for Chinook airframes is H47 not CH4.  Also on conversion from HC1 to HC2 standard in the 1990s whilst they were upgraded to similar standard to USAR CH-47D they are not designated as such in UK service being referred to as Boeing Chinook HC2 here.
You may be seeing ICAO CH4 on other Chinook records due to the corruption of ICAO code issue which is still in the hands of Airnav for fixing.  The record is now correctly annotated as H47 on the DB, but the corruption issue will prevent that being fed back to you. Consequently you will need to manually update your record.
Regards ACW367
ACW367
As a notice to users A330 HB-IQI has been transferred from Swiss Intl to Edelweiss Air.  We have amended the DB.  If users delete the photo for this particular airframe, the change will be pulled to your Navdata files the next time you pick this aircraft up on the network or local flights.
Horsham Spotter
Quote from: ACW367 on October 20, 2010, 11:24:20 PM
Hope of uses Steve.
Steve
Regards ACW367
Thank You ACW367
I will manually update the Chinook details to H47.
Steve.
Chris11
#1105
A86E85 N642VA A320-214 c/n3670 Owned by Wells Fargo but operated by Virgin America
3F75DA - One of the German Air Force - I assume could apply to any of their aircraft?
orkney
Hello
3F75DA A86E85 and 42498B All added thank you once more.
Andrew
54901 - Jim
One missing from this morning's log -->
A4EEB8 / N417GA / GALX / IAI Ltd Gulfstream 200 / Wells Fargo Bank Northwest NA Trustee / 237
Thanks!
KOSH - Oshkosh, Wisconsin USA
orkney
Hello
That is that one added thank you again.
Andrew
John Hargreaves
A new Airbus - plotting as LAA1363 at the moment
018062  5A-LAI A320  A320-214  c/n 4450  Libyan Airlines
Cheers,
John H.
