Started by Marpleman, May 26, 2010, 09:23:34 PM
#135
Just added D-OLHH with 3CF309 to the Database
There is another question I have to ask: While updating the Database, do you update the missing, false ICAO AT's as well? If you, is it in interest of you, if I post Air Craft with missing or false entry's, so you do not need to make a sweep through the whole Database?
cheers
Hi Ingo,
D-HFAX added.  Cant find anything on D-OLHH.  See PM sent
orkney
Hello
D-OLHH is a hot air ballon see here:
http://bit.ly/95H5hp
Andrew
orkney
hello
And here is an image showing The reg on the balloon from the ballonfahrt-hannover website:
Andrew
Hi Andrew!
Thank you for the research and giving the Info!
OFF topic:
Well, this will be the first Logo of a hot air ballon operator for Rod to make, I guess. ;-) I tracked D-OLHH several times, so its worse a Logo in my opinion.
Quote from: neroon79 on July 03, 2010, 04:34:40 AMWhile updating the Database, do you update the missing, false ICAO AT's as well? If you, is it in interest of you, if I post Air Craft with missing or false entry's, so you do not need to make a sweep through the whole Database?
I would guess that it must be easier to run the whole database against a list of valid ICAO codes and fix the invalid ones all at once.
Quote from: DaveReid on July 03, 2010, 10:47:54 AM
Agreed.
This one was missing in my Database Today morning:
D-AVIB    EMBRAER    ERJ-135BJ Legacy   E135   14501109     L2J         3C10AA   VIB - Vibroair   2009   PT-TKG   2009-08-21            active
Quote from: neroon79 on July 03, 2010, 11:09:46 AMD-AVIB    EMBRAER    ERJ-135BJ Legacy   E135
Strictly speaking, the ERJ-135BJ is designated the Legacy 600 (soon to be joined by the Legacy 650), not to be confused with the new, smaller Legacy 500 and 450.
Thanks Dave.
Of course your right. I have added the missing part: 600.
D-AVIB was added yesterday and as a 600
John Hargreaves
Can you add these three JAL Express please. They don't populate properly -
850E9C  JA309J  B738  Boeing 737-846  35338/2522
8514D6  JA322J  B738  Boeing 737-846  35351/3002
85153C  JA325J  B738  Boeing 737-846  35354/3117
Not that I am likely to see them - just fed up of continually manually inserting them only to see 'Tie-up extracted.................' next time I look on my database and find my input overwritten!
Thanks,
John H.
Hi John,
Only the first of those was not already in the database and its done now.
Bob SEN
Hi Alan, did you miss post 161?........... I know your a busy man.......... ;-)
cheers
Bob
1/2 a mile South of EGMC/SEN
