Started by Marpleman, May 26, 2010, 09:23:34 PM
0 Members and 6 Guests are viewing this topic.
DaveG
Correct you can only record one code and that code is also a key field so no duplicates.
I'll leave this for the others to reply etc.  Guess if mis-codes are to be retained for record in the DB entering some text in co starting with "miscode" would help - but just guessing!
Cornwall, UK
BlinkNFG
MS 4BD184 currently showing no info.  It is on route to EGSS as KYV955.
Airframes.org suggests it is TC-TLD?
thanks
Jon
Marpleman
Quote from: romdouk on June 17, 2010, 09:43:15 PM
Hi Alan/Rich,
Currently not populating:
MS: A675CD
Rgds
Terry
Hi Terry
N515UJ Gulfstream IV (cn 1051) operated by  Uni Jet, updated accordingly
thanks
Rich
Marpleman
Quote from: BlinkNFG on June 17, 2010, 10:13:17 PM
thanks
Jon
Agreed
TC-TLD B737 - 4Q8   Tailwind Airlines (cn  28199/2826)
updated accordingly
Rich
Quote from: Marpleman on June 17, 2010, 10:44:36 PM
thanks
Jon
Agreed
updated accordingly
And likely to be logged operating for Cyprus Turkish AL (KYV), as per tonight's flight into Stansted.
#36
For Registration D-ABKL there is an error in column AT: BB7- instead of correct entry B738.
And for a huge amount of other AirCraft the correct entry of the the ICAO8643 Type in column AT. It is nearly impossible to them up all...
ACW367
#37
Quote from: neroon79 on June 19, 2010, 07:55:35 AM
Neroon79, there is a bug currently on populating the AT field.  We are inputing the correct ICAO8643 codes in the Updater but the codes users are currently getting are still from the old sources that Airnav previously used. Airnav are working at this bug, but it is proving hard to identify. (see my posts on page 2)  Will let everyone know when it is fixed.
orkney
hello
Did D-ABKL's other details show up as an old lufthansa B734 or an Air Berlin B738. If it was the B738 then it has picked up the other details I added on the morning of the 17th after we had him overhead on delivery (flight BER015) with the lufthansa details.
Just interested to see if all other fields are downloading correctly onto someone else's computer.
Andrew
Except of the links to the A/C Pictures the other fields are correctly filled with Data of the Air Berlin AirCraft.
My 1st tracking of D-ABKL was today @ 7:30 UTC.
My understanding (correct me if I'm wrong) is that the current version of RadarBox never downloads the ICAO type code from the server, it simply uses the value that it finds in NavData.db3 (which an individual RadarBox user can edit if he/she so desires).
I don't understand why that seems to be causing confusion over how the process works.
For the above to change will necessitate a new release of RadarBox and/or an updated NavData.db3, so it will be fairly obvious to all when that happens.
BlinkNFG
HI,
MS: 4BA96A (Turkish Airlines) not population
Jon
BlinkNFG
CO1FEE (LOT) also not populating
thanks
Jon
ACW367
Blink Reply #46 & #47 were updated a few weeks ago.
BlinkNFG
Thanks - apologies must have missed them
Jon
