Started by Marpleman, May 26, 2010, 09:23:34 PM
0 Members and 7 Guests are viewing this topic.
HB-FRG landed Prestwick around 1335 local on its delivery across the pond.
anorak
* 3B9BFD  FNY5011    7             France - Navy        2010/08/30 14:45:02
* 3B9BFD  FNY5017    7             France - Navy        2010/08/30 07:29:35
Dave. Exmoor, North Devon.
Thanks Andrew, some were already in the d/b but still thanks.
Only amendement N110LA is operated by the Los Angeles Fire Department
I had already removed that picture and put in a row of XXXX's but unfortunately the system over wrote it.  The correct picture is there but had been moved to the second to be shown.  Corrected once again and I wait to see what happens.
anorak
andrewarles
440250 / OE-FLP / C25A / 525A-0011 to add to db.
Andrew
16 NM SSW of LFMV (Avignon)
27 NM NW of LFML (Marseille)
Arles, France.
SIGINT1
Where or to who would you report an airfield identifier change? - the Reno Stead Airfield North of Reno Nevada USA is no longer 4SD - it is now RTS - due to ILS being installed
G-ISCD and OE-FLP both added, thanks lads.
andrewarles
459501 / OY-EHA / C182 / T18208647 to add to db.
Andrew
Arles, France.
ACW367
#474
Quote from: SIGINT1 on August 30, 2010, 03:16:22 PM
That will take a long time.  Airnav utilised a professional database for airfield data when they first launched the system.  An number of airfield changes since that time have occured.  Until they procure another update for some later version, the only way you can reflect this is to create a 'custom legend' with the code and the airfield coords on the file/preferences/radarbox tab.  To match other airfields you should use the ICAO code KRTS
Andrew,
This aircraft is now SE-LXF aand is using its previous hex code.
andrewarles
459501 showed up on the RadarBox today.
Also had it on the 6/08/2010 with Callsign SE-LXF.
Arles, France.
As I said Andrew it is using its old hex code for a registration which no longer exists.  459501 is Danish, Swedish codes begin 4A
Happens all the time especially in the US.
andrewarles
Some aircraft not populating today. Info from Airframes.org or GAS
3B7B6F AF.org shows this as F-ZBFP / CL-415 / 2002 / Securite Civile but the flight Callsign was FZBFJ? To check
3B7B85 / F-ZBMD / DHC-8-402Q / 4043 / Securite Civile
3B7B9A / F-ZBPR / MBB BK-117 C2 / 9034 / Securite Civile
398C0E / F-HDAO / DA-42 Twin Star / 42.253 / ESMA - Sogelease France
3B7B86 / F-ZBMC / DHC-8-402Q / 4040 / Securite Civile
020037 / CNA-OI / Lockheed C130H Hercules / 4733 / Royal Moroccan Air Force
398D04 / F-HDIE / DA-40D / D4.382 / ESMA SA, Mauguio/Montpellier
994391 / F-GGMU / PA-28RT-201T Turbo Arrow 4 / 28R-8031014 Incorrect Mode-S noted on AF.org
398C0F / F-HDAP / DA-42 Twin Star / 42.266 / ESMA SA, Maugio/Montpellier
398C11 / F-HDAR / DA-42 Twin Star / 42.382 / ESMA SA, Mauguio/Montpellier
3B7B83 / F-ZBMF / CL-415-6B11 / 2063 / Securite Civile
380F3A / F-WWBS / A.320 / Airbus test flight - temp registration code
484C7F / PH-CBO / Pelican PL / 689 / J.A.G. van den Boogaard
398DE0 / F-HDPA / Cessna 182T Skylane / 18282166 / Pol Depasse
And yesterday
AD07CE / N939HG / AS-350B2 Ecureuil / 4802 / Aircraft Guaranty Corp Trustee, TX
3D31A9 / D-ERBD / SR-22 / 2693
3B77CF / 111 / CN-235M-200 / 111 / French Air Force, currently populating as 65 in db
3CE7FB / D-CPDR details populating "null"
A/C Name missing for the following
385E4F / F-BXSP
390DB9 / F-GDNZ
39344B / F-GNCL
394F01 / F-GTYB
395726 / F-HJPD
Andrew
Arles, France.
Quote from: anorak on August 30, 2010, 02:07:02 PM
Nice photo - an Ilyushin Il-28 (NATO: Beagle) if I'm not mistaken.
I don't think the French Navy fly those any longer :-)
