Feature Request - limit network download
Started by tarbat, March 01, 2008, 10:17:09 AM
Quick Filter in Network Tab
Dis (NM) < 000284.2
For some odd reason, you have to pick a maximum range from the drop-down list.  This doesn't filter the downloads as we already know, but it does reduce the number of aircraft in the list.
I understood this was being developed for the version after v1.4, but obviously not :(
For me at least, the high volume of data makes the network facility useless for day-to-day use, and I always use Planeplotter instead.  Probably means I won't pay for the network access when my free period expires.  A great shame really.
If you were to at least provide a workable filter on RANGE for the aircraft list, then I would probably still use it.  The current DIST (NM) filter is useless since you can't filter on DIST < 300, for example.
#17
Allocator, I've tried that, but if I filter on <300.7 for example, I still get everything that's less than 3000nm as well.  If I put any zeros in front of the 300.7, then I get nothing in my aircraft list.
I reported this back during v1.4 beta testing, but I still can't get a filter on <300nm working.
The most useful filter I've found is Latitude >55, but that still gives me aircraft over Russia, Norway, etc.
#18
Quote from: tarbat on August 03, 2008, 06:17:32 PM
tarbat, don't enter a figure in the range box, use the drop-down in the range box - this works fine for me.  If I type a figure in, it doesn't work, just as you say.
My list drops from 780 to 175 if I do it now.
http://farm4.static.flickr.com/3108/2729220174_70cde3f745_o.jpg
#19
Allocator, that's what I do.  I select 300.6 from the dropdown list, but I still get anything >1000 and <3000 as well.  Are you using the beta release or v1.5?
And how do you get leading zeros added to the drop-down list?
Quote from: tarbat on August 03, 2008, 06:39:53 PM
I'm using a beta version at the moment.  Maybe its been fixed :-)
I'm using a beta as well.  The one released on 2nd July.  Maybe they've dropped me off the beta programme :(
Airnav support, can you confirm if the problem with filtering on DIST< is being fixed, or is there something different in the setup I have compared to Allocator who can filter on DIST<?
It should be fixed, you are not off the beta list. The latest version has not been sent out yet.
Airnav Support - it doesn't appear to be fixed for me.  I don't get the leading zeros in the drop-down list.
Let me correct myself, it should be fixed in the latest version we are using :)
