Important RadarBox News - New Distributor, New Price, New Software
Started by AirNav Development, March 01, 2008, 07:34:05 PM
Roland28
It seems that I bought my RB a week too early, I had been holding off since Oct 07.
I had been also wondering why Waters and Stanton were not a supplier of the RB, I even checked their website a couple of weeks ago.
bembridge
Keen on buying thr Radarbox.  Trouble is I not so good with computers.  I was assuming that I would just plug into a USB port on my computer.  Then I see Port 30003 and Port 40004 mentioned.  Don't know what this is all about.  Will I just be able to plug into a USB port, or have I got to do some more research.  Any help appeciated
Bembridge
Deadcalm
I'm a new user - very simple, just install the software, plug in the USB cable (provided), screw on the antenna connector - and go !
DC
Quote from: bembridge on March 23, 2008, 09:23:25 AM
Bembridge
RadarBox is easy to set up and run.  A lot of the complicated chat here on the forum comes from us fanatics who just want to do more and more with RadarBox :-)
RadarBox does output data on ports 7879 and 30003, but this is to allow programmers to write software add-ons that will work with RadarBox.  In normal use, you wouldn't even know it was there.
Take a look at the frequently asked questions (FAQ) here:
http://www.airnavsystems.com/forum/index.php?board=2.0
In the unlikely event that you do have any problems setting RadarBox up, there are loads of people here on the forum who will help.
All the best
bembridge
This site has really got me "Hooked on the Radarbox,  Got a question.  I live on the Isle of Wight.  Unfortunately I know of no one on the island or in the Southampton, Portsmouth area's that I can visit for a live demo.
  At the present time I listen to aircraft mainly on 135.050 MHz bound to and from the UK.  Would I be able to listen to the voice comms  and view the aircraft on the Radarbox screen  at the same time ?  Also what is the cost of the ACARS interface program and is it available from W & S.  Also is the flight number displayed on the screen.   Guess there my be some more questions from me in the near future.
Bembridge
Quote from: bembridge on March 24, 2008, 06:16:30 PM
Bembridge
Benbridge, here is a screenshot of the IOW area taken a few minutes ago.  The traffic with a "*" after the callsign is Network traffic, that without is traffic I'm detecting using my RadarBox antenna here in Shrewsbury.  You can see the flight numbers on the map and in the aircraft list, note EZY 136Q just approaching the IOW from the SW.  Not all aircraft display Flight Numbers, if the pilot has put it in, you will see it.
You can listen to any ATC frequency you like, as there is no connection between RadarBox and your radio scanner.
Click on the link below to see the full size screenshot:
http://farm3.static.flickr.com/2296/2358899856_0334e31203_o.jpg
See here for the cost of ACARS Decoder - note that it is a 6-month reoccurring subscription.  Decoder is only available as a download from the AirNav website.
http://www.airnavsystems.com/order.html
Bembridge,
View the screenshots section for pictures around your area. With a good antenna location you should be able to pick Gatwick arrivals and departures as well Heathrow if the Downs don't get in the way too much. As well as into Northern France.
Yes with your Airband Radio you can tune to that frequency and see them Live on RadarBox. It does display the Flight Number, Aircraft Registration, Speed, Flight Level etc.. see the screenshots forum for more details.
The ACARS software is only available from our site and the cost is £18 per 6 months.
Hope that helps.
bembridge
Thank you for the replies.  All so detailed and very much appreciated.  guess I will placing an order this coming week.  Once againg many thanks
Bembridge
Deadcalm
Also, your network input from this southerly point may well help users like me (in central France) have a more contiguous view of traffic between France and the UK.
