Author Topic: Silhouetes  (Read 38396 times)
CarlosAbreu
  • The sky is not the limit
Re: Silhouetes
« Reply #15 on: December 03, 2013, 08:30:27 PM »
Hi Rod
Thank you, I'll use this one untill until appears the convention one.
CA
Cable: Ecoflex 10 (15m)
Station: XRange2 PGANRB501386
Antenna: Airnav Systems
Cable: LBC240 00220M (15m)
CarlosAbreu
Re: Silhouetes
« Reply #16 on: April 07, 2014, 10:36:42 AM »
Hi Rod
Conventional silhouete for GLF6 isn't available yet ?
Brgds
CA
Re: Silhouetes
« Reply #17 on: April 07, 2014, 10:51:53 AM »
Hi Carlos,
Try this attached
CarlosAbreu
Re: Silhouetes
« Reply #18 on: April 07, 2014, 10:54:33 AM »
Hi Rod
Brgds
CA
Re: Silhouetes
« Reply #19 on: April 23, 2014, 10:23:22 AM »
Due to the database being updated following new hex codes being allocated by the latest edition of DOC8643, the following changes will be required in your silhouette folder.  This applies to the normal silhouettes, maybe Rod would like to do new ones for photo silhouettes or change the existing?
BT36 Beech A36TC Bonanza and Becch B36TC Bonanza was formerly BE36.  I would suggest copying your existing BE36 and renaming the copy to BT36.
P28S Piper PA-28RT-201T Arrow III was formerly P28R.  I would suggest copying your existing P28R and renaming the copy to P28S.
P28U Piper PA-28RT-201T Arrow IV was formerly P28T.  I would suggest copying your existing P28T and renaming the copy to P28U.
S22T Cirrus SR22T was formerly SR22. I would suggest copying your existing SR22 and renaming the copy to S22T.
T210 Cessna T210* Turbo Centurion was formerly C210.  I would suggest copying your existing C210 and renaming the copy to T210.
T206 Cessna T206* Turbo Stationair TU206* Turbo Stationair, Cessna TP206* Turbo Stationair were formerly C206.  I would suggest copying your existing C206 and renaming the copy to T206
TB20 SOCATA TB20 Trinidad was formerly TRIN.  I would suggest copying your TRIN and renaming it to TB20.
TB21 SOCATA TB21 Trinidad was formerly TRIN.  I would suggest changing your original TRIN to TB21 as TRIN is no longer required.
XA41 Xtreme XA-41 Sbach was formerly IMPX.  I would suggest renaming your original IMPX to XA41 as IMPX is no longer required.
F26T SIAI-Marchetti SF-260T* was formerly F260.  I would suggest copying your original F260 and renaming the copy to F26T
« Last Edit: April 23, 2014, 05:28:18 PM by Runway 31 »
Re: Silhouetes
« Reply #20 on: April 23, 2014, 04:02:05 PM »
Evening Alan,
One query with regard to the above :
The information you give on the P28U. You suggest copying the existing P28T silhouette and renaming the copy to the P28T ?
Re: Silhouetes
« Reply #21 on: April 23, 2014, 05:27:44 PM »
Right Ian  you are awake and you win the prize, rename the copy to P28U.
Cheers.
    • Rod's RadarBox Downloads
Re: Silhouetes
« Reply #22 on: April 23, 2014, 07:51:24 PM »
I'll be doing new photo-silhouettes for the new codes - see my New Silhouettes thread: http://www.airnavsystems.com/forum/index.php?topic=1290.0
Re: Silhouetes
« Reply #23 on: April 24, 2014, 01:56:16 PM »
Cheers Alan,
CYYZGUY
Re: Silhouetes
« Reply #24 on: April 24, 2014, 11:40:00 PM »
Hi Rod, I have one plane populating tonight with no Silhouette
C04DDF
CGDMS (Aircraft is showing as a T210M)??
regards,
Jason
40" LED Monitor
40" LED Monitor
Re: Silhouetes
« Reply #25 on: April 25, 2014, 12:59:52 AM »
Hi Jaspn
Tp keep silhouettes all in one place, I've replied in the New Silhouettes thread: http://www.airnavsystems.com/forum/index.php?topic=1290
MIKE.UTD
Re: Silhouetes
« Reply #26 on: April 25, 2014, 03:49:43 PM »
For some reason I haven't got an XA41 old style silhouette.
Can anyone assist ?
Mike.
Re: Silhouetes
« Reply #27 on: April 25, 2014, 04:48:46 PM »
Mike I
Its not XA41 you are looking for, it is IMPX which requires to be renamed XA41, if you don't have the IMPX let me know and I will post it.
silverjet102
Re: Silhouetes
« Reply #28 on: April 26, 2014, 06:06:28 PM »
Does anybody have a standard silhouette of An Airbus A350?
Cameron
Re: Silhouetes
« Reply #29 on: April 26, 2014, 06:14:56 PM »
Hi Cameron,
A359 attached
