Whats the farthest aircraft you ever receivd?
Started by Jordan, August 06, 2010, 04:42:05 PM
Further to the above, the maximum distance on my polar diagram is to a spike in the NE at 320nm. Anyone got anything further out?
Jordan
Quote from: bratters on August 08, 2010, 09:07:33 AM
Quote from: Jordan on August 07, 2010, 11:07:31 PM
Just received 2 Air Berlin aircraft 345nm away,
one A320 DABDG and one 738 DABBT.
Although the Polar Diagram dont stretch all the way to their position..
Hi jordan - where are you based and what's your setup regarding aerial type and position?
Not quite sure what you mean when you say Polar Diag. doesn't stretch that far. It's the Polar Diagram that marks the positions - true or false notwithstanding - hence spikes.
If it reads 345nm in the Distance column, then clicking on the flight should flash up the aircraft on your Polar diag.
Well without going into specifiec about where I live, I can tell you that I live in a 12 storey bulding on the 8th floor, with nothing higher then me for hundreds of miles (the sea :) )
