Improved Routing Information
You're right Chris.  Network flights always get their route information from Airnav's server.  The only solution is for Airnav to update their server with these corrected routes.
Chris11
Yep - as I see it the only way to see if there is a new (or different) route in the server is to right click the route ID and manually check if the one displayed is different from the one you have in your local database. then manually delete (assuming your local one is correct) I like to keep databases small so this will require huse effort. Else you can just leave it and let it grow.
andrewarles
#422
AirNav,
Going back to an issue with 2 letter flightID's that are unable to show route information
http://www.airnavsystems.com/forum/index.php?topic=5333.msg56212#msg56212
will this be rectified in the next RB software release?
Andrew
16 NM SSW of LFMV (Avignon)
27 NM NW of LFML (Marseille)
Arles, France.
