New Logos
Started by RodBearden, September 05, 2010, 10:23:05 AM
vonsmalhausen
Quote from: Aerotower on September 20, 2011, 12:49:45 PM
Quote from: vonsmalhausen on September 20, 2011, 09:14:49 AM
OOSFA for SABENA flight academy
The OO-SFA is no longer in Sabena, but the CAE Flight Academy Évora.
i know, Sabena flight academy was taken over by CAE, but, at least the remaining planes over here in Belgium, are still wearing the Sabena collors and also showing up on RB as being Sabena flight academy.
all this and a big portion of nostalgia, make me prefere to show them as Sabena ;-)
Aerotower
Sorry for that, but the OO-SFA fly in Évora for CAE.
vonsmalhausen
oeps, that must be rather recent, i had it not that long ago on my box while spotting at BRU as Sabena .... well, so much for nostalgia, i'll have to switch to CAE then..... like everybody :-)
ACW367
#1263
The Brussels Sabena Flight Academy logo now features the CAE flash and not the nostalgic S in a circle.  Infact they are now fully called: CAE Global Academy Brussels Sabena Flight Academy.
http://www.sfa.be/index2.htm
Only the Sabena Aeroclub retains the S livery:
http://www.sabena-aeroclub.be/
Thanks, ACW.
So I've done two revised and I hope more legible logos - for CAE Global Academy Evora and Brussels. I've just guessed that OO-SFI has stayed in Brussels - rename it if that's wrong.
ACW367
The global academy website gives the Brussels arm as now operating only a single DA42, as SFA has been confirmed in Evora it does indeed narrow it down to SFI in Brussels.
Don't know if you had any logos against registrations for Academia Aeronáutica de Évora (mostly CS-DE*) or Sabena Airline Training Center (N- registered, based at Phoenix) but these also now are under the CAE Global Academy banner.  I have bulk changed the company names on the database server.
Thanks again, but I haven't done either of those logos :-)
A couple of Americans:
N360 - CL60 of FFL - Friedmann Fleischer & Lowe LLC - an investment management concern
N505TJ - B105 of Mercy Flight Inc
Morning Rod,
Not sure if we have a logo for this one :
OE-GVL (Using registration as flight ID)
C560  c/n 560-5772
Mode S : 44036B
Operator : Altavia
Hi Ian
I'm not at all confident that I've found the right company, but this is the logo of the most prominent company called Altavia. The logo doesn't match the circular S logo on the aircraft itself, either. It might be better than nothing!
OE-GVL - C56X of Altavia
#1270
#1271
Here you are, Ingo
PHH - Polizeihubschrauberstaffel Hessen, Hanover
EDIT again - Corrected the ICAO code
#1272
Hi Rod,
it isn't a change of name. Germany has 16 states and almost every state has its own flying police devision.
In Niedersachen (lower saxony) it is Polizeihubschrauberstaffel Niedersachsen PHX call-sign POLICE PHOENIX,
In Hessen it is Polizeihubschrauberstaffel Hessen PPH call sign IBIS
In Hamburg it is Polizeihubschrauberstaffel Hamburg LIB call sign LIUBELLE
In Nordrhein-Westfalen it is Polizeifliegerstaffel Nordrhein-Westfalen NRW call sign HUMMEL
In Sachsen-Anhalt it is Polizeihubschrauberstaffel Sachsen-Anhalt PIK call sign POLICE IKARUS
In Rheinland-Pfalz it is Polizeihubschauberstaffel Rheinland-Pfalz SRP call sign SPERBER
In Baden-Wuerttemberg it is Polizeihubschrauberstaffel Baden-Wuerttemberg PBW call sign BUSSARD
In Bavaria it is Polizeihubschrauberstaffel Bayern EDL call sign Edelweiss
In Brandenburg it is Polizeihubschrauberstaffel Brandenburg PBB call sign ADEBAR
In Mecklenburg-Vorpommern it is Polizeihubschrauberstaffel Mecklenburg-Vorpommern PMV call sign MERLIN
In Sachsen it is Polizeihubschrauberstaffel Sachsen PHS call sign PASSAT
In Thueringen it is Polizeihubschrauberstaffel Thueringen HBT call sign HABICHT
I hope this List will help and of course each devision has its own Logo...
#1273
We already had a logo for PIK and PPH (PHX) . Now we have one for PPH. Still missing are LIB, NRW, SRP, PBW, EDL, PBB, PMV, PHS and HBT.
