New Logos
Started by RodBearden, September 05, 2010, 10:23:05 AM
Chris11
#360
ICAO = GBG - Global Jet
www.globaljetdubai.com
Time for a new one for ACG?? - one with the aircraft tail as per their logo on http://www.acg.aero/?lang=1&;
phil zech
Hi Rod,
On Network this morning:
Veteran Avia  EK-74798  B747-281F    VTF624
www.veteran-avia.com  ,  non English site!
Phil
#362
Quote from: RodBearden on December 11, 2010, 10:19:39 PM
Ian - EC-KHV is now operated by Inaer - I'm sure I've done their logo before but I'm blowed if I can find it, so here it is again:
EC-KHV - A139 of Inaer
N960ES - E55P of Orion Energy Systems
Rod,
Thanks for that. It would probably explain why they used a flight ID of INR. As well as applying the logo to EC-KHV, I have also applied it to INR just in case this is going to be their way of showing the flight ID used in the future.
Incidentally, you are correct in your thinking of having done that logo before. I have found it under the flight ID of HSS but in that instance it appears as TAS Inaer. The actual logo loooks the same, therefore presumably it is the same company ?
phil zech
Hi Rod,
Pleae ignore my previous e-mail.
Found Veteran Avia, posted a few days ago,whilst updating Logos for my PC.
Phil
#364
Hi chaps.
Global Jet is another one I'm sure I've done before, but here it is again, along with the Inaer logo as I should have called it:
GBG - Global Jet (IATA 7G)
INR - Inaer
As for ACX (as Air Cargo Germany's code is), the current logo is still a current style, but here's the talfin version as an alternative (thank heavens for company sites that have logo pages!)
ACX1 - Air Cargo Germany alternative logo - rename it to ACX.bmp if you want to use it.
knight01
Need a logo for ICAO - CLJ
Got a logo for CLJ - if you mean Cello - see reply #302. I addition, I see that Avcodes has CLJ for Cello, but Airframes has stuck with Sky Light for the moment.
If you do mean Sky Light, please find a website for me - I'm fed up looking through window companies! (pun intended)
knight01
Knight01 Thank you thank you thank you!!!
THat link is the sort of thing I've been looking for for years. I do hope they keep it up to date.
To celebrate the now-confirmed ICAO code for Cello, here's their logo again!
CLJ - Cello Aviation Ltd
Rod :-)
Rod,
This one has been flying around for a few days now using his registration G-MOLO as the flight ID :
PC-12  c/n 1090
Mode S 405F23
Operator : Breckenridge Ltd (A Jersey based company).
knight01
BMI have a new logo.
#371
So here's the tiny version:
BMA - British Midland International (IATA BD)
EDIT - reloaded file because of a reported download problem.
Aerotower
#372
I Rod,
Institut Cartogràfic de Catalunya http://www.icc.cat/
ECDTS and ECIRV
Best regards
Ian - sorry, I can't find anything useful about a British Breckenridge.
Aerotower: here you are:
EC-DTS - P68 and EC-IRV - C208 of Institut Cartogràfic de Catalunya
knight01
Need a logo for LOD - Fly-Logic/Malmoe air taxi
