New Logos
Started by RodBearden, September 05, 2010, 10:23:05 AM
Here we are Rod, first of the New Year :
N55P (Using reg as flight ID)
C525B  c/n 525B-0153
Mode S A6FD9D
Operator : Jet Air Inc.
Here you are, Ian
N55P - C25B of Jet Air Inc
Currently over Switzerland, possibly on a delivery flight:
OXY - Oxygène Afrique
Happy New Year!
Finally I have some time for my RB again...
..and noticed the following Operator without a Logo:
EXC   European Executive Express (http://www.echo-express.com/ or http://www.european.se/)
unfortunately the "official" Websites (I found @ Airframes, wikipedia etc.) are more or less a dead end, but I found one here: http://www.scanair.no/aos/EEE.htm
unfortunately they don't have
Dana
Will be very useful if we can have also a flag update.....In my RB , for example, the airplanes registered in Russia  appear under the UK flag....
besty
Hi Dana,
you need to read this topic and the file you need will be on there too.
Hope that helps
Stuart
http://www.airnavsystems.com/forum/index.php?topic=5761.0
MIKE.UTD
Fantastic work as ever Rod.
Thanks again.
Mike.
Cheers, Mike.
Neroon79 - welcome back, and thanks for researching this one:
EXC - European Executive Express (IATA RY)
Dana
Thank you Stuart,
But I still not understand what settings I need to do for the russia airplanes to appear under russian flag ?
besty
The planes are registered in other countries, they are not using Russian registrations.
orkney
Hello
I think You might Never be able to see these "Russian planes" with A Russian flag. The reason is that I believe what you might be seeing are VQ-B* registered aircraft which are registered and used by Russian companies but are on the Bermuda register. At best with that new D008.Dat and flags you will see the flag of Bermuda. See below:
Extra Flags for your flags folder in the data folder:
http://www.airnavsystems.com/forum/index.php?topic=4263.msg42915#msg42915
New D008.Dat for your data folder:
http://www.airnavsystems.com/forum/index.php?topic=5730.msg59050#msg59050
By the way the real Russian registered ones Start with RA-*.
Andrew
A minor update and a guess:
TYA - Airline Taimyr, trading as NordStar
N111VM - B737 BBJ - very little info on this - one of the smartest liveries out there, but one source says that the operator is the Chinese CITIC group - so I've done that.
Bizjet:
N124EP - GLF3 of ADIR insurance
Hi Rod, you aready did a great Logo for the Polizei Sachsen-Anhalt (DHSAT), which I use for their Phoenix Helicopters. I would be great if could do the same for the Polizei Niedersachsen and their Phoenix Helicopters (DHOPE). Here the link to the homepage: http://www.polizei.niedersachsen.de/
Thanks a lot!
Here you are, Ingo - a fiddly one!
D-HOPE - S65C of Polizei Niedersachsen
and one form me:
ABL - Air Busan - new South Korean airline
