Interesting Aircraft
Started by Allocator, March 08, 2008, 08:26:33 AM
malc41
Beware wife with spade !!
15 Miles East of EGNJ
WAL 2T
#886
Just watching G-WJAN, ex My Travel 752(winglets?) with flight id of 116L. This aircraft now belongs to Thomas Cook, not sure if it's been painted yet.
Passing DCS, looks like heading towards Prestwick
Just been reliably informed that it has been painted :)
Chris
Under the EGGP 27 Centreline & 15nm from EGCC
WAL 2T
#887
A64AFB - Private B737-7 BBJ N500LS heading NW past Blackpool FL280
Departed BHX
Chris
Canonjohns40D
HI I have A64AFB - Private B737-7 BBJ N500LS now just leaving the Irish Coast Wesbound at 38000 Sqwk 7646.
John
WAL 2T
The BBJ was used by the billionaire chairman of the co. which owns Victorias Secret amongst other things. Seeing as it is on it's way back to Columbus OH I would imagine that it still is. Just something which may be of interest to the cross-dressing spotter fraternity ;)
Chris
Canonjohns40D
Hi 738C02 747-271C/SCD 4X-ICM CAL- Cargo Air Lines ICL931 Liege (EBLG) to NY (KJFK) 29950 Sqwk 0114, currently on the box.
John
Terry
    Hi there,
                 On the network now RFDS (Western Operations)
                                               VH-KWO
                                               PILATUS
                                           C/N 363
ACW367
Just recorded over London was AB2EE0 N82DU EA50 Embraer Phenom (C/N shows it is the 8th example built).  OTTSpotters have that it came across the pond and will be on display at EBACE Geneva.
ACW367
An interesting aircraft on two fronts is 4012C3 G-MASH.  It is not ADS-B but it is a transponder equipped Westland-Bell 47G built in 1969.  What makes it doubly interesting is that the registered owner is Kinetic Avionics Ltd.  The rivals in this industry.
http://www.caa.co.uk/application.aspx?catid=60&pagetype=65&appid=1&mode=detailnosummary&fullregmark=MASH
Airnav support, to keep up with the Jones's maybe you need to get your company an ADS-B equipped Hiller HT-12 or the like ;-)
markcurran
Quote from: DaveR on March 09, 2008, 02:54:54 PM
Ok, I'll try again
Thanks for all the tips. I was watching the footy but to continue would be torture for me as a Teessider. So perhaps while I'm on a role
Right better knock it off now unless I see something really good.
John Racars
Hi All,
On the screen now:
Airbus A380 F-WWOW (c/n 001);
Flightid: AIB101
Position: north of EDDL, heading nne
13 NM East of EHAM
ANRB:
Version: 3D - 5.00.072
PC: Windows 7 SP 1 - 64 bit
RadarBox24 station: EHAM4
WAL 2T
Those local to these parts may have noticed G-FPLB (ICAO:400841) Beech 200 belonging to Cobham Flight Inspection up and about for much of the afternoon. This aircraft has been calibrating the new CAT III ILS installation at Liverpool RW27.
As seen whizzing over my back garden at a rate of many knots.
Chris
WAL 2T
#897
3A3E6F Air Caraibes A332 F-OPTP flight no. CAJ551 routing towards TLA and descending. Prestwick? EDI? anyone?
F-OPTP now heading back out to the South passing Dean Cross through FL280. Flight no CAJ1552
Chris
SIGINT1
15407A Volga-Dnepr Airlines AN124 Flight VDA4325 UNNT - KVCV - Tracked going over Reno NV at 33000 FT at 2336 utc 11May
Lots of aerial photography going on today in the Scottish Highlands.  The following aircraft all logged today:
Reg   Flight ID   Type   Airline
G-BWLF         C404   Blom Aerofilms
G-MAPP   GMAPP   C402   Simmons Aerofilms Limited
G-NOSE   GNOSE   C402   Ordnance Survey
G-TASK   GTASK   C404   Ordnance Survey
PH-PIX   PHPIX   SW3   Aerodata Remote-Sensing B.V.
